Results 1 to 6 of 6
    Apr 2011
    WI
    Another Tritoon Prop??
    I have
    New 2019 Crestliner 240 Rally DX Tritoon
    27" tubes Huge Strakes on all but outer edge of outter tubes
    Center tube is full length actually 16" longer than outer tubes
    2019 merc 200 4stroke DTS 20" shaft set low as it will go.
    Can trim boat and bring bow up a good amount before props cavitate
    Tested both on same day, smooth water, low wind, approx 50 gallons of fuel
    Only me on the boat no gear.
    Props I have tried
    Merc Black Max 15.5"x15
    5600 rpm 38mph
    Solas Amita 14.8x17
    5500 rpm 39mph
    Both props seemed to run similar though the solas felt better out of the hole.
    I have a merc/quicksilver Black Diamond 14.5x19 ordered
    should be here today.
    Should I try to stay over 15" diameter?
    Any thoughts, Id like to get prop dialed in before buying a nice stainless
    Looking for a fast prop for light loads on boat to run across the larger lakes.
    Jul 2010
    Ankeny Iowa
    Based on your prop slip the black max is more efficient running about 12% vs the Solas at 19%. It could be a result of the reduced diameter.
    Dec 2010
    Knoxville, TN
    Powertech OFS 15.25X15 is a great performer on the high horsepower pontoons at pricing well under OEM. I think you are heading the wrong way from 17 to 19.......Enertia is a good one too.
    May 2001
    Ga
    We install 15 enertia's on most we sell in that size range . It really needs a laptop connected to make sure ARO is working correct. advanced range optimization . hf...
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by half fast View Post
    This 100%
    Apr 2011
    WI
    Good info thank you,
    I will do some reasearch on ARO
    and look around over winter for a 15p enertia
    This morning I ran a Solas 14.25x17 4 blade stainless, 5250rpm at 41mph, was able to trim up enough that the bow was bouncing, also able to run more trim in tight turns.
    calculated 10% prop slip
    30 gallons of fuel and just me on the boat,
    Likely 15p is the way to go with a load of people and coolers
    Thanks for all the help.
  1. Tritoon set up with a G2 300
    By skydog in forum Props, Setup, and Rigging
    Last Post: 03-12-2020, 08:45 AM
  2. Dialing in the tritoon!
    By Rynobull in forum Props, Setup, and Rigging
    Last Post: 08-08-2019, 05:52 PM
  3. Prop for a Tritoon pontoon?? Q for the toon guys
    By GlennGlenn in forum Props, Setup, and Rigging
    Last Post: 10-21-2015, 11:48 AM
  4. tritoon
    By donmac in forum General Boating Discussion
    Last Post: 08-17-2013, 11:38 AM
