Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Bigger Carb's
    Aug 2005
    West Allis,Wisconsin
    1982 Baja 184 SS. Hull is 1000# unrigged. 7.5 setback, CLE lower with 1.87 gears.
  2. #17
    minocqua, wis
    What prop , height of propshaft ,Baja , while needing more hp are generally not a speed demon 70 ish at best
  3. #18
    Sep 2017
    Ashland city tn
    Quote Originally Posted by seansbaja1982 View Post
    My buddy baja was late 70s with no interior to speak of ,except couple small seats , it was prob 700ishthats prob y performed so gud wit 115 v4
  4. #19
    Aug 2005
    Baja 184 Sun Sport 1050 hull plus engine.Click image for larger version.
ID:	448873Click image for larger version.
  5. #20
    Feb 2019
    Shawnee Kansas
    As others have stated, I would suggest you ditch the hull for a better performance design… I had that exact same motor on my 1990 STV Pro comp ski and it ran upper 90s… Was almost completely stock except for 150 psi compression, 32 cc heads...
    I think you would be amazed how much better that motor would run on an Allison, Hydrostream, STV or similar lightweight design…
    I’ve been in your shoes with an old speed liner tunnel that looked cool but would not perform… Kerry
  6. #21
    Aug 2005
    How many HP,s are milled heads good for? 20??
  7. #22
    Apr 2017
    pa
    5 Post(s)
    Didn't you already have your heads shaved?
  8. #23
    Aug 2005
    Yes, was wondering how many HP that was good for?
  9. #24
    Apr 2017
    pa
    5 Post(s)
    I doubt 20. Probably closer to 15
  10. #25
    Nov 2005
    Malta, Europe
    Wh 20 and wh 15 have a bigger bore than the rest and are best for top end they consume a lot of fuel as well.Wh 22 have better idle holeshot accelleration and better on fuel too. Wh 46 are like a better version of the 22s
    18 ft Speedcraft - Offshore
    Bottle Fed Merc tuber 2.4
  11. #26
    Aug 2005
    Ok good to know. I have to be around 225HP then with the other mods I did?
  12. #27
    Aug 2005
    I may ditch the 2.4L 200, I have a eye on a 1998 PM 225 drop on power head... Wonder how that would be on it?
  13. #28
    Nov 2005
    Malta, Europe
    PM is Better on fuel and has more torque
  14. #29
    Aug 2005
    At least I would have fuel injection, newer engine and possibly 3-5 mph more? Its stock with a brucato acu.
  15. #30
    Baton Rouge, La
    Great choice. I would think over 5mph increase with the right prop.
    Cheaters never Win !!!
  1. Replies: 6
    Last Post: 05-06-2014, 09:55 AM
  2. SD 4GB or bigger on a D80
    By rockycarr in forum Media Creation - Photo and Video Discussion
    Last Post: 04-09-2010, 09:50 AM
  3. Is Bigger Really Better?
    By Bruster in forum Technical Discussion
    Last Post: 12-29-2002, 09:28 PM
  4. Exh. Is bigger better?
    By tluckam in forum Technical Discussion
    Last Post: 12-10-2002, 12:54 PM
  5. Is it getting BIGGER.....?
    By Raceboat Rus in forum General Boating Discussion
    Last Post: 06-26-2002, 07:56 AM
