Results 16 to 30 of 30
Thread: Bigger Carb's
08-23-2019, 08:14 AM #16
1982 Baja 184 SS. Hull is 1000# unrigged. 7.5 setback, CLE lower with 1.87 gears.
08-24-2019, 01:18 PM #17
What prop , height of propshaft ,Baja , while needing more hp are generally not a speed demon 70 ish at best
08-24-2019, 01:27 PM #18
09-15-2019, 08:39 PM #19
09-16-2019, 08:44 AM #20Junior Member
- Feb 2019
- Shawnee Kansas
- 26
As others have stated, I would suggest you ditch the hull for a better performance design… I had that exact same motor on my 1990 STV Pro comp ski and it ran upper 90s… Was almost completely stock except for 150 psi compression, 32 cc heads...
I think you would be amazed how much better that motor would run on an Allison, Hydrostream, STV or similar lightweight design…
I’ve been in your shoes with an old speed liner tunnel that looked cool but would not perform… Kerry
09-16-2019, 11:08 AM #21
How many HP,s are milled heads good for? 20??
09-16-2019, 01:06 PM #22
Didn't you already have your heads shaved?
09-16-2019, 01:13 PM #23
Yes, was wondering how many HP that was good for?
09-16-2019, 01:46 PM #24
I doubt 20. Probably closer to 15
09-16-2019, 02:03 PM #25
09-16-2019, 02:14 PM #26
Ok good to know. I have to be around 225HP then with the other mods I did?
09-16-2019, 02:17 PM #27
I may ditch the 2.4L 200, I have a eye on a 1998 PM 225 drop on power head... Wonder how that would be on it?
09-16-2019, 02:46 PM #28
09-16-2019, 04:05 PM #29
At least I would have fuel injection, newer engine and possibly 3-5 mph more? Its stock with a brucato acu.
09-16-2019, 08:14 PM #30
Great choice. I would think over 5mph increase with the right prop.
Cheaters never Win !!!
Mercury 9.9 going 45 need a bigger carb, more speed..............
By jag3639 in forum Technical DiscussionReplies: 6Last Post: 05-06-2014, 09:55 AM -
SD 4GB or bigger on a D80
By rockycarr in forum Media Creation - Photo and Video DiscussionReplies: 3Last Post: 04-09-2010, 09:50 AM -
Is Bigger Really Better?
By Bruster in forum Technical DiscussionReplies: 3Last Post: 12-29-2002, 09:28 PM -
Exh. Is bigger better?
By tluckam in forum Technical DiscussionReplies: 3Last Post: 12-10-2002, 12:54 PM -
Is it getting BIGGER.....?
By Raceboat Rus in forum General Boating DiscussionReplies: 16Last Post: 06-26-2002, 07:56 AM
