Results 1 to 15 of 30
Thread: Bigger Carb's
    Aug 2005
    West Allis,Wisconsin
    Bigger Carb's
    Can there be any HP gains going to bigger carb's. Have WH22's now on a 2.4L 200 1983 5 pedal horizontal. Reed cages are also ported.
    Sep 2017
    Ashland city tn
    Mite c a small difference in holes hot or topend but not much at all , the 22s hard to beat , 15s or 20s wont idle or take off as gud but mite gain sumthin over 7000k
    Mar 2004
    Brooklyn Park, MN
    what is the best carb for a 2.4 200? I have been told the WH20's are the best, BP carbs I think.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Florida Keys
    You’re not going to notice much difference on a regular 200, but the 20’s, 15’s, 22’s, and 46’s seem to run best
    '95 STV "The Blue Goose"
    Apr 2017
    pa
    5 Post(s)
    46's
    Sep 2017
    Ashland city tn
    I agree on 46s to. I swapped from 22s to 46s not long ago , and as the idle wasnt as "clean "as 22s but there was a slight improvement everywhere else
    Aug 2005
    Do the 46's have separate jets like the 22's?
    Baton Rouge, La
    If you haven't done any block work I doubt changing the carbs will make any difference. Spend that money and cut your heads or find a set of small chamber 2.0 heads. 150lbs of compression will wake that motor up. Can still use the 22s
    Cheaters never Win !!!
  9. Likes FORBESAUTO liked this post
  10. #9
    Sep 2017
    Ashland city tn
    The 22s r great carbs , not knocking. Have run coupe sets , I like em , but like tunnel said , spend money on other mods , and maybe trade ur 22s later
  11. #10
    Mar 2004
    Brooklyn Park, MN
    The 2.4 200 I have on the Viper came with 46's I think. I have another 2.4 200 and I think that is also 46's.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  12. #11
    minocqua, wis
    The carbs all mention have 1.315 Venturi so be no gain ,do mods elsewhere like tunnel mike said
  13. Likes tunnelmike liked this post
  14. #12
    Aug 2005
    I had a partial machine to exhaust chest, 45 on transfer slots, rod slots cut, heads machined 140 compression, 5 pedal Reed cages opened up, Ccms reeds, just looking for a few more HP,s...
  15. #13
    Baton Rouge, La
    The only real difference in any of the carbs you mention is how they deliver the fuel. Like Eli said the air flow rate will be the same. Bump up to 150 lbs compression and run 91 octane minimum , confirm your jetting is spot on , and ask Forbes what to set the timing at. Without serious compression or port timing changes a carb swap most likely won't be noticeable. Imo
  16. #14
    minocqua, wis
    Wmh 47 off 3.0 liter has a 1.465 venturi but the fuel inlets I. d . as far as flow is not good 5/16 inch,I had 2 sets and they worked well on my 245's I was worried about wide open for miles and not getting enough fuel I would think you have to change inlets to 3/8 to be safe I am running wmh carbs off my 245's on my new built 260 port FF blocks and I installed 34-310 throttle blades and they idle like efi in the channels and accelerate real nice and not to bad of smiles per miles
  17. Likes Baker343 liked this post
  18. #15
    May 2013
    Huntiington Beach Ca
    Sounds like you have time and $ invested in your 2foo.
    What hull are you trying to push.
    Weight vs hp.
    If you feel your max out in your current setup and you think your porting can handle it, throw some big bores on it and let it eat.
    More air and fuel is usually good for big end.
  1. Replies: 6
    Last Post: 05-06-2014, 09:55 AM
  2. SD 4GB or bigger on a D80
    By rockycarr in forum Media Creation - Photo and Video Discussion
    Last Post: 04-09-2010, 09:50 AM
  3. Is Bigger Really Better?
    By Bruster in forum Technical Discussion
    Last Post: 12-29-2002, 09:28 PM
  4. Exh. Is bigger better?
    By tluckam in forum Technical Discussion
    Last Post: 12-10-2002, 12:54 PM
  5. Is it getting BIGGER.....?
    By Raceboat Rus in forum General Boating Discussion
    Last Post: 06-26-2002, 07:56 AM
