Results 1 to 15 of 23
Thread: Verado Pump noise level
08-21-2019, 09:02 AM #1Member
- Apr 2011
- WI
- 42
Adding Verado Power steering to my boat this winter.
Boat already has merc hydro steering.
My question
Is the pump loud enough that I would want it in the transom area under a seat?
I would prefer to mount under the helm to reduce the length of pump to helm hoses
Jon
08-21-2019, 09:47 AM #26000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
With the motor running you may just hear a hum.
If you can put it in the stern due so. The lines act as cooling for the fluid. In certain (rare) instances the fluid can overheat with really short lines from the pump to the helm. If I have to mount one under the console and have room to hide a coul of hose i always put long hoses on and hide the coil.
08-21-2019, 10:00 AM #3Member
- Apr 2011
- WI
- 42
Thank you
Great info.
I can install at the stern, under a seat, just wanted to make install easier and less holes in the boat.
This is a tri toon with large raised helm. so i could easily hide 20ft of pump to helm hose coiled under the helm
08-21-2019, 11:09 AM #46000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-21-2019, 11:27 AM #5Member
- Apr 2011
- WI
- 42
Good point,
60 amps over 15 feet would need approximately 6 gauge wire
Ill have to sit down and think about what other crap ill be putting on the boat like amplifiers and extra lighting.
It may be worth running 6 or 4 ga up to helm, or might be cheaper to just buy long hoses and put pump near battery.
08-21-2019, 01:29 PM #66000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-21-2019, 01:42 PM #7Member
- Apr 2011
- WI
- 42
08-22-2019, 09:31 AM #8Member
- Apr 2011
- WI
- 42
Going to start planning out the install this weekend.
I know there is a 3 terminal connector that goes to the motor to signal engine running for pump to operate.
Any tips on where to find it? or will it be obvious. I have to order or find a manual for the motor
2019 Merc 4 stroke DTS 200
08-22-2019, 10:21 AM #95000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Anybody know why they haven't added a mechanical pump on these motors as a option? Seems it would be cleaner and less complicated than a 60 amp electric pump.
08-22-2019, 10:30 AM #10Member
- Apr 2011
- WI
- 42
Sure would be nice, to have it factory installed instead of an auxiliary pump
08-22-2019, 08:48 PM #116000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-22-2019, 09:32 PM #125000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
08-22-2019, 11:07 PM #135000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
08-23-2019, 06:52 AM #14
I have one in my Argo right up front. Not loud at all
08-23-2019, 12:10 PM #15Member
- Apr 2011
- WI
- 42
Merc trim pump fluid level low....?
By Keaten in forum Technical DiscussionReplies: 23Last Post: 02-25-2017, 03:10 PM -
DCB M29 vs Eliminator 28 speedster 400r verado trim level
By conmax in forum General Boating DiscussionReplies: 26Last Post: 10-05-2016, 09:05 AM -
Merc 200 efi fuel pump noise after timimg out
By Scott Tharpe in forum Technical DiscussionReplies: 33Last Post: 03-25-2016, 12:20 AM -
pump noise..............could it fool ya?
By boatermike in forum Jet Boats, V-Drives and Stern DrivesReplies: 11Last Post: 08-01-2010, 09:37 PM -
noise level on newer o/b versus older o/b
By warrior1 in forum Technical DiscussionReplies: 9Last Post: 06-28-2009, 01:14 AM
