Results 1 to 12 of 12
Thread: promax vs drag 4 comparison.
08-19-2019, 08:51 PM #1Member
- Oct 2017
- york,sc
- 48
- 18
- 10
- 14
Hi looking for opinions and knowledge about props before spending money foolishly. I have a 96 Liberator 21 foot with a 2013 300xs with 1.75 sportmaster and a 12" slidemaster jack plate. the motor is set at 1" above the pad and running a 31 pitch promax. Boat runs 97mph on gps. I know Randy Corson runs Drag 4's on his and was wondering if there is a big difference in performance between the Promax and Drag 4's either out of the hole, midrange or top end. Any input will be greatly appreciated. Thanks.
08-20-2019, 07:55 AM #2
I ran both on my Talon. My 31 lab Pro max comes out of the hole slower that the 30 Drag 4 but that is the difference in Thru Hub and over hub props. I could run the ProMax higher on the jack plate before I would blow out.
dmillar thanked for this post
08-20-2019, 12:23 PM #3
I have a 2008 Lib 21 with a 300xs. My L/U is a 1.62.
I have tries a bunch of props and the best I've been able to get is
Merc Trophy Plus 28p 6100 rpm @ 85 mph
Merc Lightning ET 30p 5800 rpm @ 93 mph
Drag 5 30p 5700 rpm @ 88 mph
Ron Hill Signature Eagle 28p 6300 @ 90
Promax 29p 5800 @ 92
I'm about an inch and a half above the pad. This is with full gear and gas, 2 batteries, one person. Makes me wonder what I'm doing wrong.\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
08-22-2019, 08:22 PM #4Member
- Oct 2017
- york,sc
- 48
- 18
- 10
- 14
Thanks to LARGECAR91 and TRACEF3 for your input. I guess for now I will save my money. I was going to buy a Drag 4.
08-22-2019, 09:28 PM #55000 RPM
- Sep 2012
- Florida
- 440
- 15
- 9
- 84
08-23-2019, 10:28 AM #6
I ran 97 with the promax. Never got the Drag 4 to run right
08-23-2019, 10:09 PM #7
I really struggled with the Drag 4 on my Liberator with 300X when I had it. I ran short lakes or rivers with turns and I would have to slow down to 70 to get it to turn sharp. I ran an RE4 on that boat and it would turn in the 90's.
I'm a huge Promax fan now. I have 3 for my current boat. I would loved to have tried one on the liberator.Allison XB21 2+2
08-26-2019, 06:27 AM #8\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
08-26-2019, 06:40 AM #9
Promax looks like a four blade tempest to me. Tempest looks like a through hub lightning et
08-26-2019, 01:08 PM #10Member
- Oct 2017
- york,sc
- 48
- 18
- 10
- 14
This past weekend I was at Clark’s hill lake for the rally and I turned 6000 rpm and achieved a new top speed of 99.0 on gps. With a very slight nose up trim. Trim value didn’t change on my Smartcraft gauge just 2 quick bumps up.
08-26-2019, 01:13 PM #11
08-26-2019, 08:59 PM #12Member
- Oct 2017
- york,sc
- 48
- 18
- 10
- 14
yes with the 31 PROMAX, just me in the boat(160lbs), aprox 12 gallons of fuel at the time. boat has one OPTMIMA blue top battery (1000 cranking amps ) boat does have a sound system with amp and 6 speakers. ropes, bumpers, life vests no anchor on board at the time. I hope this helps.
DRAG 4 vs Merc. PROMAX - Which Has More BOW Lift?
By wasvette in forum Props, Setup, and RiggingReplies: 11Last Post: 08-27-2019, 05:10 AM -
2.5 200 ProMax block, cut to 260 or Drag specs?
By RedonYellowKillaFellow in forum Technical DiscussionReplies: 47Last Post: 02-24-2015, 02:31 AM -
Mercury Tech: 300 X / 300 Promax comparison
By mercracer2.5 in forum Technical DiscussionReplies: 4Last Post: 07-29-2012, 05:38 PM -
ET vs. Drag prop comparison
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 2Last Post: 04-10-2011, 10:03 PM
