Results 1 to 12 of 12
08-19-2019, 02:26 PM #15000 RPM
- Nov 2005
- 113
- 11
Who designed the 12 inch midsection and trim system for the Mercury 650-700X, T2X ?
one of the engineers at Mercury, or?
08-19-2019, 05:24 PM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
yes.
08-19-2019, 07:45 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
A guy called Chari..... strange that ya ask......he had a nite job. Just.....kidding......
Merc25sshydro liked this post
08-20-2019, 02:00 PM #45000 RPM
- Nov 2005
- 113
- 11
obviously, somebody at Mercury, but does anybody know if any one person came up with this, or a group of engineers?, ect. I have one of these mid-trims, and i wanted to know who to give credit to for the excellent engineering. hey, fugimo, i replied to your thread: Hydrostream ski wing. you might find it interesting.
08-21-2019, 12:04 PM #55000 RPM
- May 2003
- Fond du Lac WI
- 813
- 18
- 84
- 72
- 405
Ask Willabee or Butler, they might know.
08-24-2019, 03:12 PM #6
TIIX Mid Section Design ......
Around that point in time, most of the engineering changes for racing were coming out of Dick Lanpheer's group at Plt.6 in Oshkosh. I was pretty sure that the TIIX DSH was his baby, but thought I'd better ask him just to be safe. Dick was kind enough to reply as follows:
Hey Bill, it was good to hear from you! ...................................... Anyway, I digress.
On with the TIIX driveshaft housing/midsection. While this was a group effort I regret to tell you that I was the originator of that project. We were seeing some major improvements in the powerhead performance which was primarily due to volumetric efficiency and it was obvious to me that we needed to eliminate any and all restrictions to exhaust flow through the driveshaft housing/midsection. Fred Anderson was my designer and I asked him to layout on the drawing board a short housing with accommodation for essentially unrestricted exhaust flow. Meanwhile, we fabricated an aluminum rectangular “box” that could be bolted to a TII (top) and a Speedmaster gearcase (bottom) that we mounted on a propshaft dynamometer. Since we knew the propshaft horsepower and we sorta knew the gear losses of a Speedmaster, I started to hack away at the exhaust outlet. Working with the Styling Dept. (Art Miller and Bob Boede), they made a clay model complete with exhaust outlet. I had done some calculations and I think I came up with and out of 18 sq. inches and I knew that was going to be loud. From the dynamometer evaluation we pretty much verified we needed 18 square inches minimum so Fred Anderson and the styling guys got together and came up with a layout. Harry Probst was the engineer responsible for the hydraulic trim systems on all the outboards so he and Fred Anderson worked out whatever hydraulic trims issues might be encountered with the swivel bracket (my memory of that is poor since I was concentrating on the fluid dynamic issues). But anyway, from there we finalized the drawings of the driveshaft housing and had some sand castings made by our sand casting vendor in Manitowoc (I can’t remember that name either). Anyway, we obtained some sand castings, had them machined by Vern Habach’s guys in the machine shop, assembled a complete outboard and tested it. I remember that I did not review the design with Bob Johnson nor Alex since I didn’t think I needed any help screwing it up. My big concern was that the exhaust was going to be unrestricted and very loud and I was willing to take my lumps from Alex if it worked like I thought it would. After a few initial tests we verified we had sufficient exhaust flow, but I remember going back through the calculations and then designing a muffler that would fit in the drive shaft housing in case I got beat up for sticking my neck out without a way out of what could have been an unpleasant experience, if you know what I mean.
So, I hope that answers your question. Apologies for all the words, but projects like that involve a lot of cooperation and that’s how things get done.
Meanwhile, take care and I hope you are well, happy and at ease with your world!
Cheers, and try to stay out of trouble for once.
Dick
Probably more than you wanted to know, but sometimes that's what we get for asking.Last edited by willabee; 08-24-2019 at 07:07 PM.
08-25-2019, 08:36 AM #75000 RPM
- May 2003
- Fond du Lac WI
- 813
- 18
- 84
- 72
- 405
Manitowoc foundry was ECK. They also made the first 3.4 cylinder blocks, which were full of porosity - I remember we were machining them and get up to cylinder boring and end up throwing them away when you hit a hole you could stick your thumb in. ECK was good at some things but not good at making that big block. When the blocks started coming from Cosworth, it was like night and day - they prequalified the block for bore location and porosity was non existant. Ya get waht ya pay for.
FMP liked this post
08-25-2019, 04:53 PM #85000 RPM
- Nov 2005
- 113
- 11
wow!!!! just proves again, it's not how much you have, but who you know. Thank you very much, everybody!!
when i put this 650X mid on one of my boats, i'll know who to give credit too.
08-25-2019, 05:14 PM #9
I don't think the 650x mid is the same as the T2X mid
08-25-2019, 07:08 PM #10
08-26-2019, 01:26 PM #115000 RPM
- Nov 2005
- 113
- 11
when i asked the question about who designed the 12 inch 650-700X mid, i also included the t2X mid because it uses the same single ram trim system. they chose to answer talking about building the t2X mid. the same people did both, the 650x, and the t2X. Excellent engineering.
08-27-2019, 06:48 PM #12Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Great post Willabee.......History saved
willabee thanked for this postMark75H, GENE LANHAM liked this post
Mercury 3/3.2 liter 20 inch heavy duty offshore midsection with power trim.
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 2Last Post: 05-17-2019, 10:12 AM -
Mercury 20 inch V6 midsection with trim pump.
By Phil Conant in forum Misc. Parts and AccessoriesReplies: 6Last Post: 11-29-2016, 09:26 PM -
Mercury Tech: 700x midsection
By mercules1750 in forum Technical DiscussionReplies: 1Last Post: 12-17-2008, 11:50 AM
