Results 1 to 15 of 15
Thread: Fuel Pump VRO Delete
08-19-2019, 09:54 AM #1
I have a 1987 GT150. I am deleting VRO. I have two new pumps off an older 150. Both pumps have 3 ports. How can I make them work? Can I tee off of the pulse hose for both pumps?
08-19-2019, 11:40 AM #25000 RPM
- Apr 2011
- Western NC
- 113
You can tee them, It will work fine. Why are you deleting the VRO?
bullet123 thanked for this post
08-19-2019, 11:59 AM #3
Because it leaks and I never trusted any oil pumping system.
08-19-2019, 12:18 PM #45000 RPM
- Apr 2011
- Western NC
- 113
I'm about to do a start-up on a 1989 Johnson 70HP that hasn't been run since 94. I'm hoping the VRO is good the're over $400 to replace.
08-19-2019, 12:36 PM #5
Ill keep my fingers crossed.
08-19-2019, 05:56 PM #6
08-19-2019, 05:59 PM #7
08-20-2019, 07:32 AM #85000 RPM
- Apr 2011
- Western NC
- 113
08-20-2019, 01:03 PM #9Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
To the original posters question, yes you can tee them. But keep the lines as short as possible. The longer the line, the more of an increase in crankcase volume which will decrease overall performance.
I bought a 1990 140 with the vro already disconnected but still using the vro pump. Having fuel delivery problems so I replaced pump with an old style. What I did was buy a used pump off of ebay and also a pump rebuild kit. All I had to do was drill the existing bracket for the old style pump, and all was good. Total price was about $30 for pump and kit.
If you go this route, 2 things to watch for. 1 being there are so many cheap chi-knee knock offs for sale, make sure you are getting an oem pump. 2, there are 2 styles of fuel pump from the early oem. A very slight difference in the shape of the pump, but the rebuild kit is model specific.
08-20-2019, 01:07 PM #10
08-20-2019, 01:22 PM #11
1 pump isn't enough for a 150 if I understand correctly
08-20-2019, 01:48 PM #125000 RPM
- Apr 2011
- Western NC
- 113
08-21-2019, 07:39 AM #13
Im going to try to use a square pump off of a mercury a see what happens
08-21-2019, 07:47 AM #145000 RPM
- Apr 2011
- Western NC
- 113
You could even use the plastic air-cooled engine pumps that are on lawn mowers.
08-30-2019, 07:32 AM #155000 RPM
- Apr 2011
- Western NC
- 113
Fuel pump after VST delete
By pappa pete in forum Technical DiscussionReplies: 6Last Post: 05-08-2020, 02:09 PM -
WTB: Fuel pump to delete VRO
By gotboostedvr6 in forum Parts WantedReplies: 9Last Post: 05-26-2016, 06:50 AM -
external oil pump delete help merc 2 stroke
By CauZey in forum Technical DiscussionReplies: 2Last Post: 04-04-2012, 07:16 PM -
Quick weekend fix for oil pump delete! Help!
By EagleSST in forum Technical DiscussionReplies: 4Last Post: 06-28-2009, 05:35 AM
