Results 1 to 6 of 6
    May 2011
    Oklahoma City, Ok
    Tach Not Working
    Started this OB up for the 1st time after OB mechanic got it running very nice.
    all my gauges work except my tach. I have confirmed their is power to the tach.
    I dont want to smoke my brand new tach just by connecting each empty wire on the OB.
    I would "assume" its one coming out of the ECM, but you know what happens when we ASSUME.
    How to proceed?
    1996 Merc 225hp carb'ed
    If you think this is fun, wait til next weekend!
    Pekin, IL
    Grey wire in harness is tach and it hooks to the rectifier or voltage regulator at the motor.
    Rock
    Team Junk
  3. Thanks DEN thanked for this post
    minocqua, wis
    like rock said grey wire to rectifier ,when tach goes down test rectifier cause its probably toast
  5. Thanks DEN thanked for this post
    May 2011
    Oklahoma City, Ok
    i take it rectifier and voltage regulator are the same?
    I do know mechanic installed a new voltage regulator.
    Ill check this out...thank you!!
    Feb 2014
    Missouri
    Would almost take it back, nothing should be left disconnected when you pay.
  8. Likes olboatman liked this post
    May 2011
    Oklahoma City, Ok
    Thank you guys!!!
    It was the grey wire. tach now working!
  1. OMC Tech: Tach not working
    By wanagofass in forum Technical Discussion
    Last Post: 03-24-2011, 12:04 PM
  2. Tach Not Working
    By 200VEGAS in forum Technical Discussion
    Last Post: 03-30-2009, 06:24 PM
  3. 200 Mercury Tach not working
    By SAMMYBOY in forum Technical Discussion
    Last Post: 08-11-2008, 09:35 AM
  4. Tach not working
    By speedaholic in forum Technical Discussion
    Last Post: 09-10-2007, 06:52 PM
  5. Help!! Tach isn't working....
    By imq707s in forum Technical Discussion
    Last Post: 04-04-2004, 01:07 AM
