Results 1 to 11 of 11
Thread: ARP rod bolts
    Moline,Ill
    ARP rod bolts
    12 brand new for 818141 hi-perf rods $175 shipped 48
ID:	446996Click image for larger version.
    is gone
    minocqua, wis
    no way!
    Moline,Ill
    On the boat, or rod bolts?
    is gone
    minocqua, wis
    Boat
    Oct 2013
    east tennesse
    Hey what,s the APR part number, What is the main failure threads in rod or bolt top radius . Or not body "magiflux" used parts???
    you know what I mean or not
    Moline,Ill
    I'm sure ARP # is protected, these are from Mercury
    is gone
    Oct 2013
    east tennesse
    Well I,m lost from Mercury ,but ARP L 19 on bolt , No part number, I,ll sure mercury doesn,t hold exclusive on bolt,
    Moline,Ill
    Then move on
    is gone
    Jul 2012
    Huntington, Texas
    Quote Originally Posted by vtboy View Post
    Actually Mercury DOES hold exclusive on the rod bolts...
  10. Thanks vtboy thanked for this post
  11. #10
    Oct 2013
    east tennesse
    Well $12 a bolt , failure threads or bolt stretch, I quess is threads on rod , I quess thread gauge on rods no go/ go thread pitch????
    Anyone look , I know quality control i,ve never had 100 new rods to check, or check 100 used rods, any info, or just install new an hope ??
  12. #11
    Jul 2012
    Huntington, Texas
    Rod bolt stretch gauge. Uses a dial indicator to compare length of rod bolts before/after torquing. Install new is the general consensus but it is possible to get a "soft" new bolt. Probably not likely with the SPS/ARP hi-po bolts but the stock fishin' bolts are sometimes defective...
  1. ARP Rod Bolts
    By dbug10 in forum General Boating Discussion
    Last Post: 07-31-2017, 12:03 PM
  2. insuring against stuck bolts? torquing head bolts with marine grease?
    By pcrussell50 in forum Technical Discussion
    Last Post: 07-21-2015, 10:55 AM
  3. Mercury Tech: 3.0l big end bolts
    By R.grover in forum Technical Discussion
    Last Post: 09-16-2010, 06:40 AM
  4. rod bolts
    By yamahadog in forum Technical Discussion
    Last Post: 12-31-2003, 06:18 AM
  5. Rod Bolts
    By Dark Allison in forum Technical Discussion
    Last Post: 12-05-2003, 07:43 PM
