Results 1 to 15 of 18
    ILL
    2019 400R will not trim up under speed....
    It's on a poontoon and it used to trim up as high as needed. I feel it must be a limiter/setting? Even at 1/2 throttle it will only trim up about 60% but if you you are idling it will trim all the way up? Any idea's?
    Thank's
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
    Celina, Ohio
    Vesselview(smartcraft) setting. It happened to me after Mercury screwed with it at the dealer. Would only go just above neutral trim. I changed setting in Vesselview
    ILL
    Quote Originally Posted by largecar91 View Post
    Thank's man I was thinking that 100% I found the settings for the display calibration but no trim limits? It's under Vesslview?
    Thank's so much!!!
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
    May 2009
    Ormond Beach, Florida
    Check and make sure active trim is either disabled or settings are adjusted for your speeds.
    Mark
    Mar 2017
    Miami, FL
    One of my verados stopped trimming up altogether when on plane. Test it by unplugging the trim sending unit. It is located at the back of the motor by the coils. The sending unit is the little rectangle thing that sticks out under the flush port on the port side of the motor.
    In our case, unplugging the sending unit allowed it to trim again, so we replaced the sending unit and it all works well now
  6. Likes rochelle howell liked this post
    ILL
    Quote Originally Posted by Radiant View Post
    Awesome thanks!!!
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
    ILL
    Quote Originally Posted by mjw930 View Post
    I will check that tonight! I think I reamber reading if you manually trim that will disable active trim but I will check 100%
    Thank you!!!!
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
  9. #8
    ILL
    My boat setup does not have the active trim module installed it say. And I can't find any settings that would limit trim just calibration of the trim % that is displayed. When you found a setting was it like a limit for trim or?
    Thank's
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
  10. #9
    ILL
    Update
    No setting is the problem dealer hooked up there master computer and reset all trim stuff. Still no trim under power. They ordered a new trim sensor....... will update after installation.
    Thank's
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
  11. #10
    ILL
    Well put a new trim sensor on it, when I took it off water was in the little pocket where the sensor mounts and the sensor was wet. Installed new sensor 99% sure problem was fixed seeing the trim sensor was wett! But after putting boat in water no good same thing. Trim works 100% perfect until you get up on plan and past line 50 throttle it will not trim up past like 55% now.
    Help guy's!!!! Where to look next? Does engine need programming after sensor installation? Sounds dumb but I did kill the batteries last night have not done that all year. Will see what it does today.
    Thank's Skydog
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
  12. #11
    Jan 2003
    aalsmeer
    Trim fluid level?
    Burned trim motor? ��
  13. #12
    May 2009
    Why isn’t the dealer fixing it?
    Mark
  14. Likes Whaaaaat, Forkin' Crazy liked this post
  15. #13
    Dec 2001
    If it is a 3 ram.... it could be the main relief screw......Bad o rings/ broken tip that holds the last O ring......If single ram?????The hoses switched......the rev has a press relief that lets go if ya hit some thing.....at least the old ones.
  16. #14
    NE Louisiana
    Exactly... WTF????
    They laugh at me because I'm different; I laugh at them because they're all the same.
  17. #15
    Jul 2011
    Gloucester, VA
    Sounds like someone has the limits messed up.
    The dealer needs to hook up G3 and look at the counts.
    If you have smartcraft you can reset it yourself at home
  1. 2019 25' ocean express speed series
    By FSTBTS in forum Hulls larger than 20'
    Last Post: 04-06-2019, 06:10 PM
  2. Mercury Tech: speed up trim
    By new in forum Technical Discussion
    Last Post: 02-12-2018, 10:57 AM
  3. 400R vs. 400R Carbon Edition
    By whytey in forum General Boating Discussion
    Last Post: 01-23-2018, 02:45 PM
  4. Trim speed and jack plate speed
    By Krazymaan in forum General Boating Discussion
    Last Post: 06-04-2017, 06:40 AM
  5. DCB M29 vs Eliminator 28 speedster 400r verado trim level
    By conmax in forum General Boating Discussion
    Last Post: 10-05-2016, 09:05 AM
Bob's Machine
