Results 1 to 9 of 9
08-17-2019, 06:29 PM #1Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
Typical for two top cylinders to have lower compression?
Mine is a 1987 2.0L 150, but I bet this might just as well apply to all the classic V6’es...
anyway, just did my five yearly compression check and everything was 120psi, except the top two, which were both 110psi.
Is is that kind of typical for this family of motors?
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
08-18-2019, 12:03 AM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
I’ve seen it on heavy boats and heavy pitch. Most see it on 5-6 from the last cylinder time issue.
08-18-2019, 09:19 AM #35000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Cooling issue - Steam pockets?, or last 2 cyls. in line to receive cooling water, or both?
Crud in the carb(s) leaning those 2 cyls. out?
Got a 1988 2.4 175 HP. that compression tested @135 all holes except BOTTOM 2 @130.
08-18-2019, 09:27 AM #45000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
08-18-2019, 10:44 AM #56000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
It tends to run about a degree or two more then #1, so if you’re doing performance setups you time off the most advanced hole which is normally #6.
Its just rod length and wrist pin depths and crank twist all in spec but that all add up to a fast hole. Theirs quite a few write ups on timing I don’t have time to link currently. I think it’s also the lean side on some it’s the most common hole to fail.
rochelle howell thanked for this post
08-18-2019, 12:31 PM #6Team Member
- May 2009
- 1,873
- 556
- 76
- 635
- 299
- 6 Post(s)
So my numbers yesterday morning were:
110/110
120/120
120/120
Went back and checked my numbers from five years ago and they were about the same. Somebody in a post back then advised that I use 89 and let her rip. I’ve been using 91 anyway. I get the feeling I could use 87, but not sure. It is a 1987 motor so that was well into the 87 octane era.
__________
the wet:
the dry:
2003 bmw ///M5
08-18-2019, 01:02 PM #7
76-78 2.0 1750's had tight heads and need good fuel. By '79 the chambers were opened up so lower octane isn't a problem. By '83 or '84 the floats were plastic instead of foam so ethanol gas is no problem...
08-18-2019, 05:37 PM #86000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Merc put out a letter saying 87 was good when lead went bye. Unless specific noted in the ownership manual.
08-18-2019, 07:08 PM #95000 RPM
- Feb 2009
- 419
- 62
- 28
- 136
- 162
What is typical compression for '98 225 3.0lt merc carb
By CircleHook in forum Technical DiscussionReplies: 3Last Post: 11-03-2015, 11:23 PM -
97 mercury 2.5 200 xri low compression all cylinders
By basscatjd in forum Technical DiscussionReplies: 18Last Post: 09-05-2015, 07:28 PM -
Will I hate my Drag with lower compression heads?
By Hank W in forum Technical DiscussionReplies: 10Last Post: 08-15-2013, 12:02 PM -
Merc 225 EFI questions (compression, steering arm and lower mounts)
By gw204 in forum Technical DiscussionReplies: 8Last Post: 11-27-2012, 07:21 PM -
Lower Compression after rebuild AND Low Water temp
By mattyc in forum Technical DiscussionReplies: 10Last Post: 10-24-2004, 09:34 PM
