Results 1 to 9 of 9
    May 2009
    Typical for two top cylinders to have lower compression?
    Mine is a 1987 2.0L 150, but I bet this might just as well apply to all the classic V6’es...
    anyway, just did my five yearly compression check and everything was 120psi, except the top two, which were both 110psi.
    Is is that kind of typical for this family of motors?
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    Feb 2014
    Missouri
    I’ve seen it on heavy boats and heavy pitch. Most see it on 5-6 from the last cylinder time issue.
    Dunnellon, Fl. / Cincinnati, Oh
    Cooling issue - Steam pockets?, or last 2 cyls. in line to receive cooling water, or both?
    Crud in the carb(s) leaning those 2 cyls. out?
    Got a 1988 2.4 175 HP. that compression tested @135 all holes except BOTTOM 2 @130.
    What's with the last cyl. time issue? Please elaborate!
    Would it then be good practice to "jet up " on these cyls. to avoid issues, or is there another remedy?
    Feb 2014
    Missouri
    It tends to run about a degree or two more then #1, so if you’re doing performance setups you time off the most advanced hole which is normally #6.
    Its just rod length and wrist pin depths and crank twist all in spec but that all add up to a fast hole. Theirs quite a few write ups on timing I don’t have time to link currently. I think it’s also the lean side on some it’s the most common hole to fail.
  6. Thanks rochelle howell thanked for this post
    May 2009
    So my numbers yesterday morning were:
    110/110
    120/120
    120/120
    Went back and checked my numbers from five years ago and they were about the same. Somebody in a post back then advised that I use 89 and let her rip. I’ve been using 91 anyway. I get the feeling I could use 87, but not sure. It is a 1987 motor so that was well into the 87 octane era.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    Jul 2012
    Huntington, Texas
    76-78 2.0 1750's had tight heads and need good fuel. By '79 the chambers were opened up so lower octane isn't a problem. By '83 or '84 the floats were plastic instead of foam so ethanol gas is no problem...
  9. #8
    Feb 2014
    Missouri
    Merc put out a letter saying 87 was good when lead went bye. Unless specific noted in the ownership manual.
  10. #9
    Tolerance stack up, gotcha. Thanks!
  1. What is typical compression for '98 225 3.0lt merc carb
    By CircleHook in forum Technical Discussion
    Last Post: 11-03-2015, 11:23 PM
  2. 97 mercury 2.5 200 xri low compression all cylinders
    By basscatjd in forum Technical Discussion
    Last Post: 09-05-2015, 07:28 PM
  3. Will I hate my Drag with lower compression heads?
    By Hank W in forum Technical Discussion
    Last Post: 08-15-2013, 12:02 PM
  4. Replies: 8
    Last Post: 11-27-2012, 07:21 PM
  5. Lower Compression after rebuild AND Low Water temp
    By mattyc in forum Technical Discussion
    Last Post: 10-24-2004, 09:34 PM
Bob's Machine
