Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 103
  1. #76
    Dec 2001
    I got that slide show..... Commm'n......I need T4 parts #### rings... water pump.....
  2. #77
    Dec 2001
    still need # for rings and w/ pump..... nice to have # of intake gaskeyt but have mircrofitty.... so no need...whow has anyway???? dead horses thread......The 3.4 race had thinnn rings,,,,Maybefind.....
  3. #78
    Jun 2004
    florida
    you look'n for the impeller part # for this gearcase? the # 8 speedy?
  4. Likes powerabout liked this post
  5. #79
    Dec 2001
    yes.........
  6. #80
    Oct 2006
    Changes with the week
    Same impeller as just about every other hi performance mercury motor, Dave
  7. #81
    Oct 2006
    Quote Originally Posted by Merc-Cruiser View Post
    Just to clarify, the gearcase shown in this picture is a #4..the #8 came along later and looks different than the #4.
  8. #82
    ...3.4 EFI Offshore Impeller - Mercury #47-85647 ...SpeedMaster Impeller - Mercury #47-89984 ...Piston Rings - #39-88256A12 ...Cylinder Head Seals - #88251 ...Cylinder Head O-Rings - #25-88923 (If removing both cylinder heads, you need two head seals & six cylinder head O-rings) ...Port Piston - Mercury #796-816878A1 ...Starboard Piston - Mercury #797-816879A1 Just a guess on all of this. Could be completely off course. Mike Butler might be more help. On everything made at Mercury Racing/Mercury Hi-Performance, there is an original bill of materials created in the beginning. He might have access to these. Mercury part numbers on hard parts that are NLA, are just that...NLA. They have little use elsewhere. Seaway Marine in Seattle, had a few parts & pieces left, a few years ago. Now? There number is: 206-937-7373...if that's even good anymore?
  9. Likes Mark75H liked this post
  10. #83
    Dec 2001
    Thanks you Space allen......T4 had bigger DS so pump was different........ But you know that.....
  11. #84
    Oct 2006
    Sorry Dave,
    I forgot that....my bad
  12. #85
    Jun 2009
    Britsh Columbia
    I talked to the guy that owns this boat last week
    Quote Originally Posted by Dd24skater View Post
    I used to work on a pair of T-4's on 25" mids behind a 28' Apache.
    ON VACATION
  14. #87
    Jun 2009
    Britsh Columbia
    ...NOT a T-4...
    I have 2 of 3.4 L formulas EFIs with Brucato ACU and steam wheel - adapter to run 3.0 L sport masters - brand new rebuilt - run up on the hose only - looking for a boat - Ron Anderson figured they’ll make more than 400 hp tuned.
    see top
    ON VACATION
  15. #88
    Dec 2001
    Hey BC Black Max..... What exhaust housings are you using?.... I was thinking of using 3.0 housings and adapting the PH...... easyer to cut 3.0s to 20 inch than to cut 3.4s........Adapting sporty to 3.4.......the 4 bolts are close......too close to use a plate.....weld up holes and re drill.... How did you do it? thanks.
  16. #89
    Jun 2009
    Britsh Columbia
    i left the 3.4 mid Over night at Lee Davies house (F1 boat Merc Guru) he took a look at it and saw that it was close on the bottom of the mid to an Alpha and sport master pattern- he made a paper template that I took to my machine buddy - machine buddy hand bombed a 1” thick 6061 aluminum plate that bolts to the 3.4 mid with the Alpha / sport master pattern. Then we made a custom mid shaft to go between the sporty and 3.4 PH using a cosworth 25” shaft, coupled with a standard Merc coupler froma 300X that uses the stubby drive shaft like an Alpha.. Finally took the parts to a CNC guy that made them into a file that can be water jet cut out for the plates and re splined some of the shafts. The last thing was to cut down 25” water tubes and shifter shafts. It’s a few more steps - but the 3.0l power head spline is different to the 3.4 so no matter what you have to use a custom shaft between the sporty and the 3.4z
    if you look up some of my old posts there are pictures...
    i also have found the Texmo Moth- and would like to collaborate to rebuild it - and re power with my motors for some Merc demonstration events.
    Hey Merc - sponsorship?
    ON VACATION
  17. #90
    Apr 2006
    Spring City, TN
    Quote Originally Posted by BC Black Max View Post
    You might want to contact Marv Hart, he wanted to work with Brian at one time to rebuild it. Is it still at Brian's? Haven't heard from him in a while.
  1. Fail
    By head_dunce in forum The Scream And Fly Lounge
    Last Post: 03-13-2010, 10:22 PM
  2. Fail
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 08-15-2009, 09:49 AM
  3. Why Did The FBI fail and...
    By Instigator in forum General Boating Discussion
    Last Post: 08-12-2009, 07:49 PM
