Results 16 to 17 of 17
Thread: Lower unit identification
08-22-2019, 11:21 AM #165000 RPM
- Jun 2004
- florida
- 353
thanks fujimo!
08-23-2019, 10:09 AM #17Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
ive coned more then i can remember!!! how i did it, i welded all around the round part of the bullet then 3 inchs down on each side from the top and welded the top in as the cone surface travel down toward the bullet it becomes too wide to weld i leave this part untouched and level the case horizontally and pour epoxy in the void so it never collects water if a leak develops internally and it has no space left for any . me being a life time welder a filet weld is always stronger then a plug weld think about it! it coves much more surface the what u can heat up to make good weld especially thru aluminum!!!! CHAZ where u at mister ive seen your master pieces on welds with the tig
Mercury lower unit identification
By Soregon in forum General Boating DiscussionReplies: 2Last Post: 05-30-2019, 02:37 PM -
200 Mercury Lower Unit Identification
By MUDSHARK in forum Technical DiscussionReplies: 9Last Post: 03-01-2019, 08:43 AM -
By Deacon in forum Technical DiscussionReplies: 2Last Post: 07-05-2008, 04:59 PM -
Merc Lower Unit Identification???
By Moodgam in forum Technical DiscussionReplies: 0Last Post: 07-25-2006, 08:05 PM -
Lower Unit identification
By gtsmpuc in forum Technical DiscussionReplies: 4Last Post: 11-09-2001, 01:29 PM
