Results 1 to 15 of 17
    May 2015
    Illinois
    Lower unit identification
    Can anyone identify who makes this lower unit. It is made for a Merc but it has a boss cast into the housing for the installation of a nose cone water port (one on each side) I have never seen a lower that was made to have a nose cone installed. The cone is aftermarket. I sanded it down to repaint the lower and you can see where the cone was added later. It also has what seems to be a factory torque tab. It could be a weld on but there are no lines in the casting where it might have been welded on. I was just wondering who made it because it is a very cool looking lower. Click image for larger version.
ID:	446913Click image for larger version.
    Don't know if they still offer them, but many years ago Bob's sold those kind of nose cones. Looks like someone did some nice work.
    They sanded off the gearcase trailing edge factory diffuser ring cast into the housing, which I don't agree with, but the gearcase looks nice from where I'm standing.
    May 2015
    Illinois
    Thanks. I was going to remove the nose cone and install one with dual water tubes but this cone was welded on and I didn't want to deal with the hassle of removing it.
    TX......somewhere?
    merc torque master... tab added.. looks like bob's.. if welded all tha way around then bob's didn't do tha work.. excellent gear case.. one of tha best, fastest other than XR6.. jmo..
    May 2015
    Illinois
    Thanks for the info. Cone is tack welded in 3 spots on each side. Looks like they drilled three 1/2" holes on each side and plug welded it.
    if it ain't broke...
    TX......somewhere?
    Quote Originally Posted by HighVoltage View Post
    3 tack welds.. may be a bob's install then.. where are these three holes that have been plugged?
    shreveport,la
    Like tlwjkw said. Torquemaster with a Bob’s installed cone. Nice looking case
    Erik Kiser
  12. #12
    May 2015
    Illinois
    It appears that they drilled three holes on each side of the cone before they installed it. Then once it was lined up, they used those holes to tack weld the cone in place. Drilling holes and then welding inside the holes is sometimes called plug welding. Its stronger than just tack welds on the back edge of the cone.
  13. #13
    TX......somewhere?
    not a "bob's" install.. they don't take tha time ta do it that way....
  14. #14
    May 2015
    Illinois
    Don't know who installed it, but they did a good quality job.
  15. #15
  1. Mercury lower unit identification
    By Soregon in forum General Boating Discussion
    Last Post: 05-30-2019, 02:37 PM
  2. 200 Mercury Lower Unit Identification
    By MUDSHARK in forum Technical Discussion
    Last Post: 03-01-2019, 08:43 AM
  3. Lower unit identification
    By Deacon in forum Technical Discussion
    Last Post: 07-05-2008, 04:59 PM
  4. Merc Lower Unit Identification???
    By Moodgam in forum Technical Discussion
    Last Post: 07-25-2006, 08:05 PM
  5. Lower Unit identification
    By gtsmpuc in forum Technical Discussion
    Last Post: 11-09-2001, 01:29 PM
