Results 1 to 8 of 8
Thread: 260 Compression Help
08-17-2019, 12:30 PM #15000 RPM
- Nov 2016
- Geneva, Florida
- 106
- 12
I have a 260 that I had the nikasil cylinders taken out of and steel sleeves with 280 port map installed. When the sleeves were installed, the block was decked about .010 so the pistons stick out slightly.To accommodate this, I installed 1.3mm head gaskets. I have the original heads from the 260 (part #18789-C3) on it with .050 cut off them. The compression on the motor is 125psi. I am trying to figure out how much I need to have cut off them to get my compression up to 150psi. Can anyone give me a ballpark amount that I would need to cut off? Also can someone tell me what cc the heads are based on the part number? Any help would be appreciated.
08-18-2019, 10:56 AM #2
Jg,
Ballparking it is what got you to the point your at in the first place. Lets throw out, kinda, sorta, slightly and fill those spots with numbers. That way you can do it once and put it right on the button.
Accurate numbers matter, otherwise it's garbage in~garbage out. Fill in the two blanks and if you have a used gasket, measure the compressed thickness.
Remember PieR~Sq 3.14 , cakes are round, and please pass the canoli' ..
Bore : 3.500
Stroke : 2.65
Exhaust port Ht. ____
Deck Ht. -.010
Head gasket Ht. .05249
Head gasket diam. 3.530
Head cc _______
08-18-2019, 04:02 PM #35000 RPM
- Nov 2016
- Geneva, Florida
- 106
- 12
08-20-2019, 04:57 PM #46000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 431
- 64
- 434
- 452
FOR the pistons to be above deck, he had to cut more than .010 off. call jay s. to get stock below deck spec, for your year 260, to gain 25 lbs you will have to cut another ,o5o imo.
08-20-2019, 05:02 PM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
Give me a call we can chat :
832 597 2603 cst M-T 9-5Jay @ JSRE
08-21-2019, 01:39 PM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
Hope our conversation helped ya , call anytime ...
JayJay @ JSRE
08-21-2019, 02:19 PM #75000 RPM
- Nov 2016
- Geneva, Florida
- 106
- 12
Yes sir. Thanks a bunch. I sent you the payment for that indicator setup.
08-21-2019, 03:29 PM #8Supporting Vendor
- 11,838
- 163
- 11
- 795
Got your PayPal , tool on the way ...
TY ,
JayJay @ JSRE
gt 150 compression
By Coryc in forum Technical DiscussionReplies: 2Last Post: 01-21-2012, 04:25 PM -
Compression
By 1900ss in forum Technical DiscussionReplies: 0Last Post: 04-28-2008, 02:06 PM -
Compression on v6 omc
By bigobass1 in forum Technical DiscussionReplies: 9Last Post: 11-05-2004, 09:38 AM -
V-8 Compression
By Rhummer in forum Technical DiscussionReplies: 1Last Post: 01-16-2003, 11:47 PM -
2.5 compression
By Vecman in forum Technical DiscussionReplies: 7Last Post: 01-12-2003, 12:35 PM
