Results 1 to 11 of 11
08-15-2019, 10:39 AM #15000 RPM
- Apr 2011
- Western NC
- 113
2012 XS300 Trim Gauge not reading.
Why would a Livorsi Trim gauge not read when all the others do?
Water Temp.
Water Press.
Volts.
Tach.
I read that the PCM reads out digital not analog, Is the trim the only digital read?
The previous owner replaced the sender which is a 3 wire unit thinking that may be the problem. The gauge being a 2 wire, sender and ground.
What do I need to do?
Thanks, Steve.
08-15-2019, 11:36 AM #2Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
I am not familiar with your particular system, but every time the trim gauge was not working, it was the sending unit causing the issue.
Can check at the gauge if there is voltage being sent. If not, then it is the sender.
08-15-2019, 12:02 PM #35000 RPM
- Apr 2011
- Western NC
- 113
All connections check out and the sender was just replaced prior to my purchase.
08-15-2019, 04:05 PM #4Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Assuming your sender uses ground for signal, here is the list.
--Positive voltage at gauge. If no positive voltage, why? Blown fuse? Bad wire? Bad connection?
--Negative voltage from sender to actuate gauge? If no, why not? Bad wire in between? Bad sender? Bad negative connection to sender. And if there is negative voltage at gauge, does it vary with trim position of motor?
--If all these check out and there is both positive and negative at gauge, then bad gauge.
08-15-2019, 07:13 PM #56000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
3 wire is digital 2 wire is anolog. Switch the sender
08-16-2019, 07:34 AM #65000 RPM
- Apr 2011
- Western NC
- 113
Is there a 2 wire trim sender available for the 300XS with offshore mid?
08-16-2019, 07:46 AM #7Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
I have never seen one of the "puck style" senders work accurately for any length of time. If you are depending on it for a neutral position reference at speed, then go to a Stainless marine indicator.
08-16-2019, 07:58 AM #86000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-16-2019, 10:02 AM #95000 RPM
- Apr 2011
- Western NC
- 113
08-16-2019, 10:47 AM #106000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
You could get an AGI to convert to analog
08-16-2019, 02:53 PM #115000 RPM
- Apr 2011
- Western NC
- 113
Spoke to Mercury Customer service and they stated that if the other gauges are working I already have the correct wire harness installed and need to look at the wiring to the gauge or a gauge fault.
trim gauge not reading right
By rbodine in forum Technical DiscussionReplies: 5Last Post: 11-05-2009, 05:20 PM -
Fuel gauge reading zero
By Mean Dean in forum Technical DiscussionReplies: 8Last Post: 05-26-2009, 12:20 PM -
EGT gauge not reading one side,why?
By Hirk in forum Technical DiscussionReplies: 2Last Post: 10-06-2008, 10:47 AM -
New volt gauge reading different than old one...HELP
By motoxconnection in forum Technical DiscussionReplies: 17Last Post: 06-23-2007, 10:16 PM -
tachometer reading on Faria gauge
By stevek in forum Technical DiscussionReplies: 3Last Post: 06-06-2003, 08:42 AM
