Results 1 to 8 of 8
    Apr 2018
    Missouri
    xr6 Lower unit change
    I have a '92 150 xr6 S/N-0D137211. According my research the lower unit is a 4 1/4 inch diameter gearcase with a 1.87 gear ratio. Will a 4 3/4" gearcase fit this motor and will there be any performance difference?
    Thanks
    Small cases have a 1.78 ratio. You may need to reprop or buy the filler ring for your prophub to close off the exhaust
  3. Thanks Iron Horse thanked for this post
    Likes tlwjkw, Iron Horse liked this post
    TX......somewhere?
    https://bobsmachine.com/product/blow-out-ring/
    maybe/maybe not?.. try it without first.. its gonna ventilate but sometimes that's a good thing.. depends on purpose and your overall rig...
  5. Thanks Iron Horse thanked for this post
    Likes Iron Horse liked this post
    shreveport,la
    Depending on your application, the larger case with a 1.87 may be better
    Erik Kiser
  7. Thanks Iron Horse thanked for this post
    Apr 2018
    Missouri
    Thanks for the info guys. Re-propping is a definite as it was over propped when I bought it. Any recommendations on where to get a good reman lower unit at a fair price? Also looking at props but there is a ton of different ones out there. Prop will be going on a Ranger451V. Length 17.5 ft. 84'beam Speed is not the #1 priority but looking for a good balance between hole shot and top end. Any recommendations on props to consider would be appreciated.
    Sep 2017
    Ashland city tn
    Prolly trophy or similar for a good starting point
  10. Thanks Iron Horse thanked for this post
  11. #7
    Apr 2018
    Missouri
    Thanks Merc
    You are the second one to recommend a Trophy, so I am going to try to find one to test.
  12. #8
    TX......somewhere?
    if ya go to a bigger case try a tempest also if ya run across one..... kinda scarce but work good on some rangers..
  13. Thanks Iron Horse thanked for this post
  1. 3.0 liter Lower unit design change?
    By 2.5-21 in forum Technical Discussion
    Last Post: 02-14-2018, 08:59 AM
  2. Lower Unit Change
    By Blazer95 in forum Technical Discussion
    Last Post: 06-19-2010, 11:11 AM
  3. OMC lower unit change?
    By drjerry1st in forum Technical Discussion
    Last Post: 04-19-2010, 12:28 PM
  4. Change, My Lower Unit
    By MIJI in forum The Scream And Fly Lounge
    Last Post: 11-16-2008, 12:39 PM
  5. Lower Unit Fluid Change
    By fantastixvoyage in forum Technical Discussion
    Last Post: 07-03-2003, 09:54 PM
