Results 1 to 4 of 4
    May 2009
    Change the old wiring or, if it ain't broke don't fix it?
    1987 2.0l 150hp...
    I have every reason to believe my pretty good running 2.0l has all old original wiring. The stator had the yellow wires with the insulation all brown and cracked with large bits of it missing altogether... Yet... It actually ran pretty well for the last two years until it developed a miss at idle. The trigger/timer base wires are all that soft noodle feeling, so I ordered a new trigger to replace my old one. I am thinking of just going ahead and ordering a new engine harness and primary wires too.
    What do you think? Good idea? Bad idea?
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    Sep 2017
    Ashland city tn
    I've personally never had a motor harness issue ,but if u wanna change u can, I believe those wires last longer than stator or trigger wires
    Jul 2005
    AZ
    Short answer yes worth it!
    What's it look like what do wires feel like and gauge.
    Ever have any electrical problems before?
    I would check all the wires for corrosion etc use a gauge and see.
    Wires/insulation terminals deteriorate with age and movement and if the other wires are shot it's worth the (mine were $90 a piece cdi)for piece of mind
    And hell just looked ALOT better
    I usually replace wiring if its old or looks iffy.
    Different motors but I replaced mine when I was building the new powerheads.. harnesses were 88..
    Never had a problem Ran great..
    But when I took them off I checked the wires and definitely not in great shape..
    Ive come across a bunch that ran fine but were crap and some you would think there's no way this thing ran but
    '84 Checkmate Convincor
  4. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    May 2009
    Thanks, guys.
    I’ve already changed the stator and trigger with the scuzzy wires. It just feels better having new wires. I suspect the wires are as old as the motor itself (1987 2.0l 150). Even the engine harness is wrapped in black electrical tape, though the wires I see look decent enough.
    Say, how durable are the primaries that run from switch boxes to the coils? Mine look pretty decent.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  1. Replies: 9
    Last Post: 10-24-2013, 08:50 PM
  2. Did ya change yer clocks? SOON, in 3 weeks, watch how broke ya be..
    By Robby321 in forum The Scream And Fly Lounge
    Last Post: 03-26-2012, 09:31 AM
  3. prop change ? or gearcase change.
    By jlay in forum Props, Setup, and Rigging
    Last Post: 11-13-2010, 09:36 PM
  4. You wanted "CHANGE", you got change....for the worse
    By 302w in forum The Scream And Fly Lounge
    Last Post: 01-15-2009, 08:16 AM
