Results 1 to 8 of 8
    May 2011
    Oklahoma City, Ok
    OB Not for Sale Any More (@ least for now)
    I had posted in the classified my Merc OB for sale...but I found out the lower was SEI and was junk, crack gearcase.
    After shopping around for one, NOT SEI. OEM is expensive, REALLY EXPENSIVE!
    The mechanic that got my OB running sweet told me to call his buddy.... which I did.. I pick up a lower for OEM for $400,
    Only problem is a 20"drive, I need 25". Was going to buy a new driveshaft but came across driveshaft extension and look into this.
    I brought one.
    I had several people inquire about my OB for sale, I'm just glad I didn't sale it with a junk lower.
    Some of you had seen some of my pic from my boat build so I'll share some photos.
    Still waiting on fuel tank parts so I haven't run it yet.
    I really wanted to see how it sit in the water.
    Water is coming over the back just a little, but motor is trimmed back about half way, nobody inside and no fuel no one board.
    Battery placement is up front under the cowling.
    Will see how this work out with the weight of this ob before I attempt to sale again.
    6 and a half years I waited for this moment!!
ID:	446753Click image for larger version.
ID:	446754Click image for larger version.
    If you think this is fun, wait til next weekend!
  2. Likes delawarerick liked this post
    Sep 2012
    besides the driveshaft extention, you will also need the shift shaft extention, water pressure hose and the spacer. Make sure you have a very, very good bilge pump. Wishing you the best!
    May 2011
    Oklahoma City, Ok
    dont need all that.......lower is exact same except length of drive shaft...extension is all I needed.
    Miami,Fl
    Good luck keep us in the loop
    Sep 2012
    Quote Originally Posted by DEN View Post
    Without the shift shaft extention....how did you shift?
    Mar 2017
    Miami, FL
    He already has a 25" mid. So everything is the correct length. Lower is a 20" so he just needs a longer driveshaft
  8. Thanks DEN thanked for this post
    May 2011
    Oklahoma City, Ok
    Thank you Radiant, I couldn't have said THAT better.
    I received my extension today and installed....Worked prefect, but getting the shift connector back in place was a PITA!
    Ill gease up the gearcase tomorrow, install the prop, I got all my part now for the fuel tank, just a little bit of wiring left then to the lake Sunday.
    BTW, I brought the extension from Bay manufacturing in Milan, Ohio. very nicely done shaft.
    Kinda pricey, but better then buying and installing a new/used driveline
    May 2011
    Oklahoma City, Ok
    Got everything together, started up for the 1st time after the OB mechanic run this fingers thru it...
    it snaps right over...YAHOO! All my gauges work except my tach. none of the wires coming from my remote
    would work. ill post another thread for this.
    https://www.screamandfly.com/showthread.php?345913-Tach-Not-Working&p=3156225#post3156225
