Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 53 of 53
  1. #46
    Jul 2005
    AZ
    Ok sounds better
    '84 Checkmate Convincor
  2. #47
    Sep 2013
    Eastern LI
    what about the jets? Would you sell the 64Ds? What do you want for 6? I'm eastern LI...
  3. #48
    Jul 2005
    AZ
    I sent a dm would need address etc if your interested
  4. #49
    8 Post(s)
    Quote Originally Posted by pdmoney View Post
    What did you do with the thermo cover story, which system are you running?
  5. #50
    Sep 2013
    Eastern LI
    What are you referring to? I didn't have to change a thing from the 86 to the 89 head thermostats.
  6. #51
    Sep 2013
    Eastern LI
    The only other mod I am considering doing if you even call it a mod is putting the Chris Carson reeds in. I had them on the '86 2.7 I just haven't swap the intake to the 89 engine yet. I have a new set of reeds also. I'll probably take some time and clean up the intakes and try to fabricate or get the Chris Carson Reed stuffers and modify them to fit and make sure everything clears. I ordered the 23 inch prop witch should be here by the end of next week I'm excited to get out there and give it a try.
  7. #52
    Jul 2005
    AZ
    You use different thermostat covers 70hp(those aren't the the 70hp but) and different hose routing
    You fill that area for better water follow for cooling
  8. #53
    Sep 2013
    Eastern LI
    Ok, now I need to ask for help on the Tach if anyone has input. I just swapped a "New" regulator, it was a CDI regulator from the 2nd engine I bought of a pair...Still no tach working... Does the wire that the tach gets the signal from run through the key switch? I know the harness plugs in to the control box and then back out to the dash.. This is really got me now...it used to work when I got the boat with the original '86 200 XP.. Is something different in the harness for an '89? BTW, I am heading out now with the new jets, the prop I ordered on Ebay was lost by Fedex so now I am back to square one on getting the bigger prop..I'll let you know how it works with the new jets..Just dont have time to mess with the tach any more now..
  1. Replies: 51
    Last Post: 06-18-2019, 03:25 PM
  2. Time to best the dead "black max", "black box" horse.
    By Quinten in forum Technical Discussion
    Last Post: 09-16-2013, 06:24 AM
  3. Mercury Tech: 70 horse
    By TEXAS20225 in forum Technical Discussion
    Last Post: 03-29-2009, 07:42 AM
  4. vro (dead horse) 225 mercury
    By huffdaddy in forum Technical Discussion
    Last Post: 11-14-2002, 09:37 AM
  5. Sea Horse 5 1/2
    By hrvx in forum Outboard and Racing History
    Last Post: 06-05-2002, 08:46 AM
