Results 1 to 7 of 7
    Differences between Optimax Air Injectors
    Im running an 04 200XS. Do I have to look for 200XS specific air injectors, or can I replace them with the newer blue or gray ones from 150,175,200,225,250, or 300, even if they do not list my part numbers in the compatible part numbers list???
    Feb 2014
    Missouri
    I have not done this so I can’t say
    what I can say is they are calibrated like fuel injectors to add x amount of air, and you could end up to lean or rich pdq.
    Dec 2017
    Lake Ashby, New Smyrna Beach FL
    There are many companies that sell and service them. Try asking Brucato
    May 2014
    Livingston, Louisiana
    I’m pretty sure there is only the blue and grey. Definitely need to stay with color as it’s the calibration. They ain’t cheap new, I’m dealing with this on a 150 opti I’m building. Had five bad ones that are sticking at higher pulse widths. Five new ones was gonna be close to 2500, along with build, this baby is is totaled. Problem with used ones is getting a good one is a shoot match due to all the compressor failures, and if comes off a blown motor, the debris from the bad cylinder also gets into the injectors. I found a set of 5 used ones cheap and sent to Brucato and only two where good. But, hey got two for less than one new one, just gotta try and find three more.
    Are you looking for the blue ones or the gray ones?
    May 2014
    Blue
    Feb 2014
    Missouri
    Glad you didn’t say black.
  1. Optimax injectors
    By skatermike24 in forum Parts Wanted
    Last Post: 06-24-2015, 04:34 PM
  2. 135/150/175 optimax differences
    By lokinutz in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 03-07-2012, 09:55 AM
  3. differences between optimax and older 2.5L ??
    By strehl in forum Technical Discussion
    Last Post: 07-27-2011, 01:45 PM
  4. Optimax air injectors?
    By xr6 in forum Technical Discussion
    Last Post: 03-14-2010, 08:24 PM
