Results 1 to 7 of 7
Thread: Single Ram trim pump
08-13-2019, 09:38 PM #1Junior Member
- May 2019
- Grand Bay AL
- 24
I know this has been discussed alot but I can't find exactly what I need to know. I have the factory trim pump on my 260 and want to find a faster 12v pump. I was told the Bob's jackplates pump is alot faster. Can anyone tell me exactly what I will need with it. I read you have to use a different reservoir cap and will lines have to be remade or can you adapt to the pump with fittings?
Thanks for any info. I'd like to order what I need tomorrow
08-14-2019, 10:04 AM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,643
- 606
- 922
- 1698
- 7144
- 3 Post(s)
There are different pump internal gears to speed or slow the fluid flow. Parker makes several pumps that offer 3 different flow rates each. Scott Porta of Porta products is very knowledgeable on them-you might want to give him a call.
08-14-2019, 02:59 PM #36000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
I HEARD something about using a mercruser pump in place of the o/b pump? think its higher volume/flow.
08-14-2019, 03:02 PM #4
KIRCHNER thanked for this post
08-14-2019, 04:49 PM #55000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Any difference in speed/ volume between the different out drive models? Alpha, bravo, etc.?
08-15-2019, 08:20 AM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
08-15-2019, 08:43 AM #7
https://www.parker.com/Literature/Hy...%2012-2015.pdf
https://ph.parker.com/us/17560/en/co...nit-108-series
Performance will vary with the type of fluid used.Hydraulic Fluid
Acceptable fluids for 108/118/165/175 Series Power Units:
• Standard Automatic Transmission Fluid (ATF)
• Most mineral based hydraulic fluids. Viscosity range: 32-64 cSt (150-300 SSU) at 38°C (100°F)
Stock mercury single ram trim pump vs mercruiser style trim pump on a 2.5L
By Brookbbb in forum Technical DiscussionReplies: 2Last Post: 02-24-2017, 10:21 PM -
single ram oildyne trim pump
By bec in forum Technical DiscussionReplies: 0Last Post: 09-07-2012, 12:08 PM
