Results 1 to 5 of 5
08-11-2019, 08:37 AM #1Junior Member
- Oct 2018
- panhandle
- 13
2007 300xs odd fault/smartcraft issue.
Engine has offshore mount/trim. Getting a fault that states “ trim sensor angle or improper propeller, see dealer”. Puts engine into guardian mode.
I’m running the same propeller that’s been on the boat since new.
As for the trim, engine is all the way down when trying to get on plane.
The crazy part with all of this is my trim has never been correct, even if I calibrate it, it’s still not right. Any advice would be greatly appreciated.
Im thinking trim sensor is toast and telling my Ecm that engine is in trailer position, or shift switch is bad and telling ecm boat is in neutral. Just not sure how I could troubleshoot this.
08-11-2019, 01:58 PM #2Screaming And Flying!
- 14,700
- 380
- 1280
- 5599
- 10931
Dis-connect trim sensor and run it. Dis-connect the shift sensor and run it.
08-11-2019, 02:25 PM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Check tps voltage and cps
under pitch comes from load sensor tps and rpm not matching the map.
Trim should be digital sender. Check to see if it’s been bumped or the analog got hooked up.
Setting its a pain. Worked on mine 2 weeks to get 0 0 and 10 10
09-08-2019, 02:57 PM #4
Have you reset the tach to go back to default yet? I read you have tried to calibrate it but is it seeing Zero or starting somewhere else..? Try resetting the default calibration and then see where it shows your starting point is.
09-10-2019, 03:06 PM #55000 RPM
- Apr 2017
- Pomona ny
- 251
- 12
- 48
Like mentioned above check tps
2007 300xs dbr l1.1
By ROCKETMANJP in forum Outboard EnginesReplies: 4Last Post: 03-01-2019, 06:32 PM -
300xs low voltage fault
By Bcv33oceanhawk in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 11-06-2015, 09:51 PM -
300xs fault code.
By Turborr in forum Technical DiscussionReplies: 3Last Post: 12-08-2014, 09:58 PM -
Smartcraft guage reading Fault oil level?
By mikeg in forum Technical DiscussionReplies: 3Last Post: 05-26-2006, 04:12 PM
