Results 1 to 3 of 3
08-10-2019, 03:27 PM #1Junior Member
- Aug 2018
- Gothenburg, Sweden
- 13
Mercury Laser 220 XRI EFI. Lacks power and runs uneven/missing.
I'm still fighting my 220hp Merc and I feel like I'm tried every trick in my book with no success.
So far the following things been done:
New sparkplugs
Watersprayed ignition components
Ohm tested sparkplug wires
Put on extra ground cable to the ECU
Checked for corroded ground cables
Got the injectors tested, none is leeking or clogged
Cleaned throttlebodys and housing
Cleaned all fuel filters
Compression test
Checked vaacuum hoses
Well, I think that is all, I don't know how to proceed in the troubleshooting. It still runs uneven with a fluctuating tachometer.
How should I proceed? All input is welcome since I'm really on my own in this since there isn't a outboard mechanic that got a clue about these engines in Gotheburg, Sweden..
Please help me guys.
08-11-2019, 07:42 PM #2Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Might want to post in Tech section instead of Buy and Sell. Probably get better response.
08-14-2019, 07:49 PM #3
I had one drive me crazy until I found bad plug on bottom injector. I think this is not unusual because it collects moisture when it sits for a while. Hope this helps.
The impossible I do right away, miracles take a little longer.
1989 Mercury Black Max 150 - problems with power, missing on cylinders
By trevstar in forum Technical DiscussionReplies: 57Last Post: 08-18-2016, 04:37 PM -
Runs great-compression 100-no power, no plane out
By Dentquip in forum Technical DiscussionReplies: 2Last Post: 09-03-2011, 08:08 PM -
Merc Laser 220 XRi runs bad when trimmed down
By gmacrae in forum Technical DiscussionReplies: 81Last Post: 11-02-2010, 03:57 PM -
115 merc runs then lacks power?
By chevzr2 in forum Technical DiscussionReplies: 12Last Post: 07-27-2008, 11:30 PM -
Please Read Post On Tec Line About Power Head Missing Parts
By Jay Smith in forum General Boating DiscussionReplies: 0Last Post: 06-12-2002, 08:41 PM
