Results 1 to 15 of 15
08-09-2019, 03:47 PM #1
Point me in the right direction-Poor idle
Just put my Mirage in the water for the first time in about 8 years. Stock 1988 (I think) 200 Merc. Low water pick up, oil injection removed. Before I started the motor I went through the carbs but they looked great. All fresh fuel (old gas was drained long time ago). Started up without much issue. Runs good on the hose but when I put her in the water, she does not want to idle, cuts off. Does this in or out of gear. Have to give it some gas to keep it running and even then it is rough and might cut off. Once off idle everything seems normal. Gets up and screams along just fine. Only issue is when I have to slow back down to an idle. Please point me in the direction to start looking. P.S. Forgot how much I liked buzzing along in this old girl. Thanks Joey
08-09-2019, 03:53 PM #2
I would get 3 carb kits and go through it all and replace all gaskets and make sure there is nothing stuck in an air port or something like that. Maybe even the needle not stopping the fuel flow and its flooding the motor some? We just had to do that to a 200 as well. I think you can get 3 kits with needles and seats for 75-80 bucks on ebay shipped. Maybe something is plugged up under the top plate on the carb?
1973 Viper - sold
1978 Viking - sold
1995 XB02
08-09-2019, 03:54 PM #35000 RPM
- TN
- 470
- 7
its flooding to death from fuel puddling in front of reeds and then is carried into cylinders through bleed lines. they make restrictors to put in lines to slow it down. fiberglass reeds can help. be sure sinc and link is correct and set idle timing for 600rpm+ in gear. i start in gear and set my idle at 800rpm or higher.
08-09-2019, 04:12 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
low speed stator isu.....or... bad fuel pump rubber.... DaaDaachngeee. Or if ya didn;t clean the Tubes....From top to bottom.......
08-09-2019, 06:11 PM #5
Pull breather off and pump ball and see if fuel floods out of carbs , float stuck open flood out ,stuck shut run lean and sneeze alot
08-09-2019, 06:29 PM #6
I appreciate all the replies and suggestions. My only question is would the above situations result in it idling fine while on the hose out of the water but bad when in the water?? Just curious, seems like it would be bad out of the water as well. Of course I am a complete amateur which is why I turn to you guys for guidance. You all have way more knowledge and experience than I will ever have. Thanks again.
08-09-2019, 06:57 PM #76000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
MY 200 always idles higher on the hose. than at the ramp. when the mid is submerged back pressure effects idle rpm. im at about 900 on the hose but lower in the water. maybe just turn up the idle abit and see how the rpm is at ramp. that would be an easy fix.
08-09-2019, 07:04 PM #8
The idle "quality" shouldn't change , only a lower idle, but if u pit n water and wont idle , u have a prob, always idle good on hose compared to submerged
08-10-2019, 06:16 AM #9
Thanks again, yes it idles decent on the hose and it is a little higher on RPM. In the water it is lower RPM and wont stay running at idle. Even when I give it some throttle it wont idle for very long. It dies and is not easy to re-start. Once we are up and going everything seems normal and runs like a champ,
08-10-2019, 07:30 AM #10
08-10-2019, 10:54 AM #116000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Might just need adjustment depending on what screws were moved and parts ect... if it has the different carb on one or two spots check their on the right spot.
If thats good this group group here will help you get it lined out
08-11-2019, 04:51 PM #12
Well I did some checking around and ran a compression check just to make sure all 6 were up to snuff ( I know leakdown is the better test but compression tester is what I have) anyway, all six were fine. I went ahead and adjusted the idle up some. Idles about 1000 on the hose. Took it out today and idled pretty good in the water. It starts right up and will idle in the water, would not stay running in water before. Idle quality is about as good as I remember it being, I don't recall this or any of these old motors idling very good anyway. Now got another issue. Will post separately Thanks to all for feedback. Joey
08-15-2019, 06:51 PM #13Team Member
- May 2009
- 1,883
- 558
- 77
- 637
- 307
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
08-15-2019, 08:25 PM #145000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Yep. If you're squeezing the primer ball firmly after it gets hard, and no fuel is leaking from carb throats you should be o.k.,
pcrussell50 thanked for this postpcrussell50 liked this post
08-16-2019, 02:32 PM #15
Mercury Tech: point me in the right direction
By mt0264 in forum Technical DiscussionReplies: 3Last Post: 09-24-2012, 07:01 PM -
OMC Tech: 140 CF backfire, poor idle performance
By 930turbo in forum Technical DiscussionReplies: 31Last Post: 08-26-2012, 12:42 PM -
OMC Tech: Revisiting V8 Poor Cooling at Idle
By Li'l Toy in forum Technical DiscussionReplies: 9Last Post: 12-21-2011, 11:07 AM -
2.5L XRI EFI poor idle problem
By camrynekai in forum Technical DiscussionReplies: 52Last Post: 06-19-2009, 12:00 PM
