Results 1 to 9 of 9
    Apr 2016
    new brunswick
    alternative for 28 chopper ?
    I have a 225 EFI promax sheared shaft on a sportmaster 28"pitch chopper lost at sea, it was on a 19'5 tunnel 90ish MPH boat
    ANYONE know if a 27P Fury will run at high transom settings prop shaft level to boat bottom ? better or worst? I am upgrading to fat shaft need to modernize my prop selection
    thanks for your feedback
    Sep 2017
    Ashland city tn
    Fury wont run near as hi as a chopper will , fury fine if ur carrying lots weight , if lookin for speed, go back with over hub props
  3. Likes friendbroker liked this post
    Feb 2011
    HUDSON, FLORIDA
    I KNOW 1 exception a solas scorpion, a thru-hub that runs way high and smooth 3 blade, high rake, tons of lift. seems everyone who runs one, gives a great review. i run a 24, reallymeasures at 26p. takes a flo-torque. keeps up with my chopper, less torque. there are some tests on S/F about them also called an S3 model. 1/2 $ of merc prop. there 2'' stiff. you would need a 26''= 28 chopper.
    Feb 2011
    HUDSON, FLORIDA
    I KNOW 1 exception a solas scorpion, a thru-hub that runs way high and smooth 3 blade, high rake, tons of lift. seems everyone who runs one, gives a great review. i run a 24, reallymeasures at 26p. takes a flo-torque. keeps up with my chopper, less torque. there are some tests on S/F about them also called an S3 model. 1/2 $ of merc prop. there 2'' stiff. boatid marine 289$ new
    Apr 2016
    new brunswick
    Quote Originally Posted by KIRCHNER View Post
    thank u I ordered an eagle four Ron Hill 4 blade 28p going to give that a try
    Sep 2017
    Ashland city tn
    I would run a 26 4 blade vs 28 3 blade to keep same rpm
    Dec 2013
    georgia
    Quote Originally Posted by friendbroker View Post
    How did they work for you
  9. #8
    Apr 2016
    new brunswick
    I like it,, the 28 4 blade is better all around with only a slight drop in top RPM maybe 200rpm
  10. #9
    Dec 2013
    georgia
    I have a set of eagle 28s coming this week to hopefully replace my 28 bravos if I get the bow lift I'm looking for
  1. SRX alternative
    By bigboy in forum Props, Setup, and Rigging
    Last Post: 12-12-2018, 04:31 PM
  2. Alternative to carpet.
    By David in forum Fiberglass and Composites Discussion
    Last Post: 01-15-2017, 10:35 PM
  3. alternative to surfacing wax?
    By groundloop in forum Fiberglass and Composites Discussion
    Last Post: 01-17-2015, 05:12 PM
  4. Gas alternative,,,,,,see video
    By YELLOWXD in forum The Scream And Fly Lounge
    Last Post: 03-19-2006, 09:37 PM
  5. Carpet Alternative
    By SHADOW in forum General Boating Discussion
    Last Post: 06-06-2002, 09:57 AM
