Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Boost bottle?
    Aug 2011
    Lake Mälaren, Sweden
    Boost bottle?
    Anyone tried boost bottles on two stroke multiple cyl outboards?
    We run them on my sons two stroke bikes with great result (much smoother idle and stronger low end.
    Attached Thumbnails Attached Thumbnails 022F3B3A-8940-4A84-9E2E-BBC12AD8F79D.png
  2. Thanks SS Minnow thanked for this post
    Likes SS Minnow liked this post
    Sep 2017
    Ashland city tn
    The bikes as in 1cyl?
  4. Likes SS Minnow liked this post
  5. #3
    Jan 2015
    I am always looking for every but of power I can find, and from what I have seen, you are too.
    Just a quick search finds some interesting info.
    http://www.3wheelerworld.com/showthread.php/1527-What-does-a-boost-bottle-do-for-a-2-stroke
    The reason we have reeds are because of the "spit-back" you describe Tejas (i dont know if u said that, i didnt read all your post). A person who says they are junk probably doesnt know much about motors, because they help a lot. If a 2 stroke is ever out of tune (without a boost bottle or reeds) the air/fuel mixture will spit out the carb really bad, and you will even get exhaust fumes sometimes. A boost bottle catches that fuel coming back, and lets it go easily back into the cylinder each time piston comes down to let in fuel/air. Thereby improoving throttle response, and power. This idea is rather new and very true. I know a guy that uses this technology in conjunction with other technoligies of his own design and makes engines get 50% better gas mileage and 10 times better throttle response. All this with a carbed engine too. His 350 chevy of this design with a 550 holley 2 barrel got 30 miles to the gallon while making close to 500hp. He uses this technology on all his machines and twin turbo V-max 600 sled. You may not believe this, but it is very true. He has had this idea for over 10 years, but has tried to been bought out by oil companies, manufactures, and other but none of them wanted to pay him. One company in particular stole part of the idea and made engines that ran worse but didnt know why, yet sold them anyway. Tucomshe to be exact (I tried the best on the spelling).
    Sep 2017
    Ashland city tn
    I would def like to know more bout multi cyl 2 strokes , I can see if working especially on single cyl mota ,,but I'm thinkin how it would work on a v6 merc haha. , wish I had a experimental mota
    Jul 2015
    northern lower michigan
    Ski Doo snowmobile had the boost bottle on earlier 2000's, 2 stroke, 2 cylinders and then they faded away with fuel injection.
    Feb 2014
    Missouri
    Crank fed outboard it’s not that effective. It works the opposite of stuffers. Before the reed it might. But not much behind the reed.
    many cars have them in the stock intake tubes, it improve throttle response and works as a silencer
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Merc 2.5 View Post
    Look at the way the Merc V6 is set up, it's a big stack of single cylinder mota's (thank you Jerry Hale)...
    Aug 2011
    They need to be mounted between reeds and carb!
    My experience is that they need to be placed above the intake. I’ve used a program called bimotion to calculate hose length, canister size etc. When using this software you can decide at what rpm you want the bottle to work (its resonance rpm). Lower the rpm, longer the hose.
    Aug 2011
ID:	446179As an example; my sons scooter moped, just shy of 20hp. Homemade (by me) intake mainfold. Boost Bottle attached just short of the reeds. Much smoother idle and better response.
ID:	446180A simple chart showing different hose length at various rpm. Ok, Swedish text, but I think you get the idea... Bimotion.
ID:	446181Looper being built in my garage, just an idea of where to place the nipples for the hoses.
    Jul 2007
    Bay City, Texas
    So I am guessing you would need a bottle for each cylinder?
    You reap what you sow, corny but true.
    Aug 2011
    Quote Originally Posted by ssv170 View Post
    I think so, but I am not sure. I think Yamaha used their YEIS-system on two cylinder applications whereas the two intakes shared the same bottle!?
    Some interesting reading:
    http://www.dragonfly75.com/motorbike/YEIS.html
  14. #12
    Calgary, Alberta
    If you find some pics of a Dave Bush OMC drag motor from 10+ years ago I think you will see he tried tbis.
    Matt
  15. Thanks Captain75 thanked for this post
    Likes baja200merk, Captain75 liked this post
  16. #13
    Quote Originally Posted by MattGreen View Post
    Matt
    Yep
  17. Thanks Captain75 thanked for this post
  18. #14
    Aug 2011
    [QUOTE=SS Minnow;3153363]I am always looking for every but of power I can find, and from what I have seen, you are too.
    Yes, always!
    Its time to start deciding the p/h mods for the upcoming winter.
    Right now I’m a bit short of ideas, apart from perhaps some adapter mods to straighten the exhaust path.
  19. #15
    Aug 2011
    Matt
    anyone got access to these pics?
  1. On the bottle
    By wriedt1 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 11-09-2008, 10:34 PM
  2. anyone on here bottle fed?
    By Fearless in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 09-05-2008, 09:02 PM
  3. Boost bottle
    By paulfox74 in forum Technical Discussion
    Last Post: 03-24-2006, 09:50 PM
