Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
    Oct 2013
    east tennesse
    1985 mod vp or not
    Hi Is this a real mod vp 2.4 or what # 6285294 Thanks
ID:	446066   Click image for larger version.
ID:	446067   Click image for larger version.
ID:	446068   Click image for larger version.
    Oct 2013
    east tennesse
    sorry about pic,s
  3. Thanks nitro_rat thanked for this post
    Dec 2001
    your dog PISSED on my leg...... Who cares.... it looks like a good one.....They all blow up.....nice find.
    Oct 2013
    east tennesse
    Love that dog
    Dec 2001
    dogs are better than most people.......
  7. Likes tux974, H2OPERF, robert jordan liked this post
    Dec 2001
    My Dogs
    My Cute Duo
    An Old Favorite From The Past
  9. Likes tux974 liked this post
    Oct 2013
    east tennesse
    stop , I mite have to like you, why do i save boats? 1. spend more $ then worth, 2. always going to water to test 3. alway can go faster
    4. girl friend hates speed/water loves to talk, but dog loves water /speed / doesn,t talk
    Dec 2001
    don't know what that Merc is...... but it looks good.......most in the day had big/horns.... that's a mixsmaster? But ya don't know till the rod droppps....hit yas on the head........JMO DAVE.....
    Sep 2017
    Ashland city tn
    Quote Originally Posted by vtboy View Post
    No that's not a mod vp , fishin motor , race cowl,
    Maybe orig modvp went down and replaced power head , looks like 1 piece plate and cle,lite weight flywheel
    Oct 2013
    east tennesse
    no pulse lines on block fishing ???
  14. #11
    TX......somewhere?
    this... sign of hi perf, bp probably....
    front has been painted so back probably was to... build date on block?.. heads at least '87... newer ecu..
    Moline,Ill
    Quote Originally Posted by Merc 2.5 View Post
    Case injected "fishin' motor" ?
    is gone
  16. #13
    Jun 2014
    Midwest
    Started out as a Single Port Down Draft at One time from the Looks of it.
    Was adjusted as it aged to keep it a float.
  17. Likes nitro_rat liked this post
  18. #14
    Oct 2013
    east tennesse
    Well The clock on the wall says 3 oclock, number on clamp is 62852294 and the lower is 2 hole factory, got lite weight flywheel, but paint and the heads big what the flip, sounds good turned 6500 on 24 chopper pushing water logged eluder, i thought my 13 boston whaler with old 65 hp mercury is faster, so whaler needs more prop, and i,m scraping now looking for numbers, casting plugs ? and ?,
    what should psi be 130 bp and 140 mop vp factory I quess , then leak down . Well it was cheap, Thanks for help
  19. #15
    TX......somewhere?
    its a hot rod.. been painted for whatever reason.. no bleed nips on tha cylinders, more than likely a BP, efi front end.. probably matchin' halfs.. may be original from up draft stuff ta block deck.. those parts could possibly jive with clamp serial number (pre '87) but later heads, later ecu.. there is a build date stamped at tha bottom of number 2 on block half, might be on tha flange.. will be 1/8" numbers, m/d/yr. might be hard ta see but its there... kinda behind tha bend in tha timin' arm...Click image for larger version.
    serial on clamp is jus that, a serial on tha clamp.. cle was added.. wasn't being built in tha up draft era... anything stamped on tha welsh plug?.. motor that old with unknown heads 115 (all close) or better would be ok for starters.. jmo.
  1. Replies: 2
    Last Post: 07-10-2015, 09:11 PM
  2. 1985 Bridgeport EFI on 1985 STV Shovelnose prop question
    By MISSING in forum Props, Setup, and Rigging
    Last Post: 02-28-2012, 03:53 PM
  3. xp 200 1985?????????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-15-2009, 12:25 PM
  4. 1985 Xr2
    By jjmalkow in forum Technical Discussion
    Last Post: 03-04-2007, 04:42 PM
  5. 1985 omc v4
    By ram4fun29 in forum Technical Discussion
    Last Post: 06-01-2002, 09:02 PM
Bob's Machine
