Results 1 to 15 of 28
08-02-2019, 07:39 PM #1
Injector cleaners as maintance service?
Before retiring the dealership used BG-K44 and was the only product approved and covered as warranty for injector issues. They all claim to work such as techron, quick-clean, seafoam, and many more. An engine with NO running issues... what's proven to work?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
Glasstream15 liked this post
08-02-2019, 08:34 PM #25000 RPM
- Apr 2010
- Indian Lake Ohio
- 330
- 74
Seafoam
08-02-2019, 09:35 PM #3
BG gonna be hard to beat. Unbelievably good products. If they make it, it works. We use BG products at the shop and have seen amazing results from quieting noisy a/c compressors, p/s pumps, cleaning carbon from intake/valves, cleaning injectors, rust penetration and the list goes on.
Capt.Insane-o, Glasstream15 liked this post
08-02-2019, 11:13 PM #4
I've had good results with seafoam. Been keeping the injectors and carbs clean on my motors. Seafoam even took the carbon buildup off the lawn mowers exhaust valve....thing ran like it was brand new
08-03-2019, 05:16 AM #5
Every Injector whether it be Bosch, Khein, Yamaha etc or Automotive, marine, Jet Ski, Motorcycle, Snow mobile etc has a small screen pressed in the intake end of the injector. No amount of Injector cleaner or Brand for that matter can remove the trash build up that those little tiny screens capture. Injector cleaners only keep the Injector nozzle clean thats it!!! When I do Race injectors we dont replace the screens as we prefer to rely on the filters in the fuel system to filter any trash before it gets to the injector. Those filters should be taken apart and cleaned or replaced on a regular basis. On all other applications I install new injector screens. The only other way to remove the trash those little screens trap is to remove and replace them (which takes a special removal tool) or to reverse flush the injectors which can only be done on a Injector machine. And some times that works and some times it dont!!! Anyone that dont believe me Text me @ 757-544-1787 and ill text you two videos of injectors on one of my machines that shows Flow before the screens are removed and after. I tried posting them but cant get them to down load. And as far as the Mercury Bosch Race injectors the screen cant be removed unless the hose if cut off. Because Ill guarantee you there is no way on Gods Green earth youre going to pull it off. Then a new hose needs to be installed.
08-03-2019, 07:19 AM #6
A place I used to work at had a air powered machine that you mixed a cleaner and gas into the reservoir then added air regulated to correct psi and ran the engine off it for a minute or so. Worked fantastic, i don’t recall the brand name though
08-03-2019, 11:40 AM #7
Dealer VW/AUDI shop had similar tool but ran 100% on the cleaner. personal VW 2L(60K miles) with direct injection had bad carbon/crap on the intake valves which cause misfire on cold startup. I ran BG intake cleaner and it missed even more. Took the intake off and all the buildup got mushy... so I had to manually walnut blast to clean. BG guy said I should of been doing the cleaner every oil change, which on VW was 7500miles(OUCH)!Checkmate 2002 Convincor 270 496 MAG-HO
08-06-2019, 03:40 PM #8Supporting Vendor
- 11,838
- 163
- 11
- 795
My vote is for Seafoam
Jay @ JSRE
JR IN JAX liked this post
08-06-2019, 06:59 PM #9
My vote is no screens and Seafoam....I do run a lot of Chevron gas with the Techrolene in it out of the pump.
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
stoker2001 liked this post
08-07-2019, 10:43 AM #108000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Mercury issued a bulletin to take the screens out of the injectors I use mercury quickleen and if you can find the Bosch injectors that were made in Germany the far better than the ones that were made in Spain
08-07-2019, 10:50 AM #11
08-08-2019, 04:23 AM #12
Michael can you PM or email me that Bulletin Please? jbcincnc@aol.com
THANKS!!!
08-08-2019, 06:09 AM #13
Me too. Thanks in advance
trace@cfl.rr.com\\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\/// \\\///
08-08-2019, 07:36 PM #14
If there is such a bulletin I believe it was for 260/280 injectors. Im looking for it.
Michael J Giesler liked this post
08-10-2019, 01:00 PM #156000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
you can buy straight techron by chevron at walmart. good for gum and varnish. my merc guy uses chem-dip at NAPA.
injector service
By NICE PAIR in forum The Scream And Fly LoungeReplies: 7Last Post: 07-24-2013, 09:46 AM -
Injector Cleaners
By Still Crazy in forum Technical DiscussionReplies: 33Last Post: 04-21-2011, 09:23 AM -
Evinrude Injector service, who does them
By BenKeith in forum Technical DiscussionReplies: 0Last Post: 04-09-2008, 04:48 PM -
Power Performance Injector Service
By Liqui-Fly in forum General Boating DiscussionReplies: 7Last Post: 12-22-2003, 11:03 AM -
who not to use for injector service
By NPW in forum Technical DiscussionReplies: 0Last Post: 05-31-2001, 08:26 PM
