Results 1 to 7 of 7
08-02-2019, 11:05 AM #1thowell327 Guest
Gear cable adjustment? Hopefully not bad clutch dog
Just bought a new to me eliminator daytona 22 with a 300xs on it. I was out on the lake yesterday testing props and getting a feel for the boat. It goes into gear in forward and reverse awesome no problems, what i noticed though is on heavy acceleration the gear shifter wants to pull towards neutral. It never popped out if gear or anything it just worried me because you can watch it fall a little bit and it becomes hard to push it back up all the way while under acceleration. Hopefully its a out of adjustment cable. This is from my rookie research im no merc mechanic. Hopefully someone has dealt with this. Thank you!
08-02-2019, 11:08 AM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,641
- 606
- 920
- 1698
- 7138
- 3 Post(s)
They will often pull back when you let off the gas. A lot of guy will use a bungee to hold it forward if you don't have a locking shifter.
08-02-2019, 11:43 AM #3thowell327 Guest
Thats interesting, if its normal than i wont worry about it. Thanks!
08-02-2019, 12:00 PM #46000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
I'd install a locking shifter to make sure it stays in gear solid. At least that's what I did. First time i ran a 3 liter sporty my detente shifter came out of gear. Lowers are too expensive to mess around with. Installed the N Control locking shifter.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
08-02-2019, 12:07 PM #5thowell327 Guest
08-02-2019, 12:28 PM #66000 RPM
- Aug 2015
- Southeast
- 1,068
- 134
- 79
- 48
- 614
I have no idea. This is what i installed. https://www.hardin-marine.com/p-1360...t-shifter.aspx Spring loaded pin that drops into the face plate. It's solid fit. The shifter I had prior looked identical, but it just had a ball bearing on a spring that sort of caught in a small hole. It wasn't a solid hold by any means. The new one is hinged side to side at the bottom and you have to pull the lever straight towards center of boat in order to pull the pin out of the hole then shift forward or back.
Blazer 650 Pro Tour
08-02-2019, 01:52 PM #7thowell327 Guest
Does anyone have experience adjusting the detent on these shifters? Its the offshore one that all the eliminators seem to have. A guy another thread said he had the exact problem and the marine shop adjusted the detent on the shfter and fixed it.
3L left hand gear set and clutch dog
By lift2win in forum Parts WantedReplies: 0Last Post: 08-05-2018, 09:09 PM -
OMC Tech: Evinrude cable adjustment
By Captain75 in forum Technical DiscussionReplies: 5Last Post: 07-28-2014, 09:19 AM
