Results 1 to 11 of 11
08-01-2019, 09:47 AM #15000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
Land & Sea 1 pc exaust plate or 2.4 1 pc
Is the Land & Sea 1pc plates with the built in tuner good for a mild lake built 260 ? I have access to a 2.4 1 pc and tuner as well ? the Land and Sea is new and the 2.4 has been in saltwater and will take some work to clean up . just trying see witch one I should use ? I also have a oval equal length tuner I thing came out of a drag but it does not match the square ports on the 2.4 plate . Thanks for any help
08-01-2019, 12:19 PM #25000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
That land & sea runs good ..
08-01-2019, 01:29 PM #3
1st pics not a 2.4 plate.
08-01-2019, 03:16 PM #45000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
What is it ?
08-01-2019, 05:55 PM #5
Later 2.5
08-01-2019, 09:01 PM #6
Well..what's left of one..
Dave Strong liked this post
08-02-2019, 08:10 AM #75000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
08-02-2019, 09:07 AM #8
Is there not a tuner in there already? I wouldn't bother with the oval. I like the rectangle bell tuner best but doubt you'll see a difference in any of them. If the land and sea is the "short" one it may loose a little on the lower end.
The original 1750 cast in tuner, the 2.4 200 tuner, and even the 225 pro max tuner are all the same length. If it falls off in the can you might notice a rattle but probably little to no performance difference unless you're on a dyno!
08-02-2019, 09:10 AM #95000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
yes the 2.4BP in the picture still has the tuner in it
08-02-2019, 09:15 AM #10
08-02-2019, 10:40 AM #115000 RPM
- May 2019
- Sandy run SC
- 118
- 10
- 37
thanks for the reply , the mid is going to Marty Powell to be cut to 15"
Dry Stacked Exaust Plate
By rockit in forum Misc. Parts and AccessoriesReplies: 6Last Post: 08-20-2018, 06:14 PM -
another exaust plate ?
By check88 in forum Technical DiscussionReplies: 2Last Post: 10-05-2001, 04:11 PM
