Results 16 to 30 of 36
    Feb 2007
    Western Washington State
    Was their a change in temp and humidity from the higher numbers. 90-100 temp can rob 500 rpm vs. 50-70. Some older carb motors even have cold hot stop levers so you don’t over run when it’s cool out.
    Nope.
    Chris, I'll give a call tomorrow probably late in the day. West Coast time and all. Thanks.
  2. #17
    Jan 2015
    For some reason the above link leads to nothing, sorry about that. It worked before. Will try again.
    https://www.screamandfly.com/search....archid=4968856
    ETA, that works much better. Must of just copied and pasted wrong link.
  3. #18
    Feb 2007
    BTW, here are my comp readings: #1-120, #2-128, #3-122, #4-130,#5-119, #6-129. Not great, but still within 10%.
    SS Minnow - The hyperlink above doesn't work. Sorry.
  4. #19
    Dec 2001
    reed stops and Breck point.....Where the reed starts bending.......Also plst reeds are stiffer .... than ss....jmo....
  5. #20
    Dec 2001
    your comp # are with range......
  6. #21
    Sep 2017
    Ashland city tn
    Just grab a thinner set from chris and see how it goes , I'm sure i got steel reeds that was n good shape when took off ( use at own risk) I'll check if ur interested
  7. #22
    Feb 2007
    New problem!
    Uh oh.
    My engine just started missing. It has been backfiring/sneezing through the top carb on the starboard side at idle. What could this be?
  8. #23
    Sep 2017
    Ashland city tn
    A miss or pick up tube stopped up b my guess , unless u broke a reed I highly doubt the reeds is sneeze issue, do u have a spark tester? Miss at idle or what rpm? Or from idle to wot
  9. #24
    Feb 2014
    Missouri
    On the other hand that sucks, but might have discovered the real power issue.
    Could also be unrelated
  10. #25
    Feb 2007
    Quote Originally Posted by Merc 2.5 View Post
    I have a multimeter. Not sure how to use it in a case like this, though. I can also tell you that while I was running it in my driveway I pulled the #1 plug wire from the plug to see how differently it would run, and got grounded GOOD. Seems it isn't a spark issue. I can't make it replicate the problem in the driveway. It needs to be under load. It sneezes back through carb at dead idle in gear, 700 rpm. I doubt it's a reed, too. If it was a reed it'd be leaking comp back through on every up stroke of #1 piston.
    No matter; I hope to find out tomorrow what the prob is as the reed block is coming out to put new reeds in.
  11. #26
    TX......somewhere?
    pull cowl and start after dark...
  12. #27
    Feb 2007
    Hehe. The neighbors will LOVE that - smoke and noise...What would I be looking for? Flames in a carb throat?
  13. #28
    Jul 2011
    Gloucester, VA
    Lean sneeze? Where are your mixture screws?
  14. #29
    Feb 2007
    Quote Originally Posted by RSWORDS View Post
    The thing is, the carbs haven't been touched. Why would it suddenly start leaning out? Plugged idle jet, vacuum leak... Those seem like the only real possibilities.
  15. #30
    TX......somewhere?
    Quote Originally Posted by croSSed View Post
    move a grounded screw driver around all tha wirin', especially tha coils and plug wires...
  1. 1990 150 xr4 verticle to horizontal reed and carb change
    By BASSCASTER in forum Technical Discussion
    Last Post: 06-11-2014, 06:28 PM
  2. Reed change
    By Captain75 in forum Technical Discussion
    Last Post: 02-11-2013, 08:17 PM
  3. Lose of power and running ruff
    By FISH2611 in forum Technical Discussion
    Last Post: 06-14-2012, 11:53 AM
  4. it's 2007 reed change again! AND BIG IMPROVEMENT
    By The Big Al in forum Technical Discussion
    Last Post: 01-23-2007, 10:54 AM
  5. lose power while trimming.
    By spanky2002 in forum Technical Discussion
    Last Post: 09-26-2002, 04:50 PM
