Results 1 to 15 of 36
Thread: Reed change lose power?
07-31-2019, 12:27 AM #1
Has anyone ever heard of a Mercury V6 losing high-end horsepower by switching to after market reeds? I "upgraded" to carbon fiber reeds awhile ago, and while the engine seems to run better at displacement speeds and seems to have better low-end throttle response, I've lost 2 mph and maybe 300 rpm at WOT. I don't know what else could have caused this. I'm going to check compression tomorrow.
07-31-2019, 05:27 AM #2Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
A reed change can cause a drop in power if the new reeds are too stiff.
Erik Kiser
Capt.Insane-o liked this post
07-31-2019, 06:05 AM #3Bud Conner "Heathen" "Defending Our Constitution"
ssv1761982, nitro_rat liked this post
07-31-2019, 06:24 AM #4Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
Someone on here did a reed comparison years ago, it was very informative. Reeds are critical....
07-31-2019, 06:57 AM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
Eric is correct too stiff a reed will limit ability of a stock engine to “draw” vapor into intake I use only TDR reeds and a .022” composite reed I do NOT use carbon fiber reed valves on any motor I build , race or recreational for that reason ...JMO
JayJay @ JSRE
07-31-2019, 07:02 AM #6Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
I just reviewed the reed tests, very interesting.
07-31-2019, 10:25 AM #75000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Have a link to the reed tests?
07-31-2019, 10:48 AM #8Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
07-31-2019, 11:45 AM #9Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
I gave up on the search and went google. Typed scream and fly reed tests. https://www.screamandfly.com/archive.../t-206831.html Near the end of the thread
07-31-2019, 05:06 PM #10
That was VERY interesting. I wish I hadn't thrown away my stock steel reeds or I'd swap them and check numbers again.
I have a 2.0L 150 XR2, so the reeds are horizontal. I hate to say it, but the reeds are CCMS reeds. It runs a little better at displacement speeds and "seems" to have better low end throttle response, but the boat is at least 2 mph slower and was turning up 6200-6300. Now I'm only getting 5900. I want my old reeds back!
07-31-2019, 05:31 PM #11
07-31-2019, 08:44 PM #12Nitrous is like a slut. u wanna hit it but you know there will be consequences.
08-01-2019, 01:59 AM #13
You are correct. Sorry. Semantics problem. As to the other comment from bigblue454chevy, I get it. But, you're full of it. I've operated this motor on this boat with this set-up for at least 10 years. It doesn't run like it used to, BUT...I haven't taken a compression reading yet.
08-01-2019, 07:17 AM #14Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Give a call so we can figure this out,Chris,305-394-3354
XstreamVking liked this post
08-01-2019, 04:10 PM #156000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Was their a change in temp and humidity from the higher numbers. 90-100 temp can rob 500 rpm vs. 50-70. Some older carb motors even have cold hot stop levers so you don’t over run when it’s cool out.
1990 150 xr4 verticle to horizontal reed and carb change
By BASSCASTER in forum Technical DiscussionReplies: 2Last Post: 06-11-2014, 06:28 PM -
Reed change
By Captain75 in forum Technical DiscussionReplies: 11Last Post: 02-11-2013, 08:17 PM -
Lose of power and running ruff
By FISH2611 in forum Technical DiscussionReplies: 1Last Post: 06-14-2012, 11:53 AM -
it's 2007 reed change again! AND BIG IMPROVEMENT
By The Big Al in forum Technical DiscussionReplies: 67Last Post: 01-23-2007, 10:54 AM -
lose power while trimming.
By spanky2002 in forum Technical DiscussionReplies: 7Last Post: 09-26-2002, 04:50 PM
