Results 31 to 36 of 36
Thread: Reed change lose power?
08-15-2019, 03:45 PM #316000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
08-15-2019, 03:53 PM #32Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Damn, just seen this. I will try one more time, just differently. Here goes:
https://www.screamandfly.com/showthr...ight=reed+test
Hopefully that works as they are good reads, pun intended.
08-15-2019, 03:58 PM #33
After you find one of the vacuum lines fell off .. come back and tell us what color it is ...
08-15-2019, 07:37 PM #34
Make sure the throttle plates are closed at idle. Anytime you disturb a carb you should check and make sure the "synch" wasn't upset.
08-17-2019, 01:24 AM #35
Well folks, I think I found the problem. The reed block gasket on the top, starboard side had slid in and there was a vacuum leak on the #1 cylinder at that point. I took apart the whole reed assembly to check it out, and put it back together with new gaskets. Hopefully, tomorrow I'll get to test run it.
nitro_rat liked this post
08-19-2019, 01:39 PM #36
1990 150 xr4 verticle to horizontal reed and carb change
By BASSCASTER in forum Technical DiscussionReplies: 2Last Post: 06-11-2014, 06:28 PM -
Reed change
By Captain75 in forum Technical DiscussionReplies: 11Last Post: 02-11-2013, 08:17 PM -
Lose of power and running ruff
By FISH2611 in forum Technical DiscussionReplies: 1Last Post: 06-14-2012, 11:53 AM -
it's 2007 reed change again! AND BIG IMPROVEMENT
By The Big Al in forum Technical DiscussionReplies: 67Last Post: 01-23-2007, 10:54 AM -
lose power while trimming.
By spanky2002 in forum Technical DiscussionReplies: 7Last Post: 09-26-2002, 04:50 PM
