Results 1 to 12 of 12
Thread: 250 pro xs performance mods?
07-30-2019, 11:14 AM #1Member
- Jun 2019
- Tulsa
- 32
ANY suggestions for a 2014 mercury pro xs 250 running a 1.75 sport master case on an eliminator scorpion. I know about the ecu, exhaust tuner, lightweight flywheel am I missing anything? I get 85 with a 15x30 performer bc4 4 blade prop
07-30-2019, 11:55 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Sell the 250, get a 300......jm2cts
RSWORDS thanked for this postDavid - WI, RSWORDS liked this post
07-30-2019, 01:39 PM #35000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
If you need more hp just sell the 250 and get a 300. Little to no gain for the $ you will spend.
07-30-2019, 02:10 PM #4Member
- Jun 2019
- Tulsa
- 32
Selling isn't really an option I just bought it 3weeks ago. Supposedly the new outboard 5 blade cleaver can gain 10 to 12 mph according to mercury, and I'm betting if I just lowered my fuel load and lightened the boat some I can get into the 90s as is. Is the magnum tuning bolt on sensor tricker alright or should I send the ecu in for a reflash, they both claim 15 to 20 percent hp gain but about a 400 dollar difference
07-30-2019, 02:16 PM #55000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
Prop work I agree with...but most of the people that have done upgrades to the 300xs benefit mostly from the higher rev limit. Ecu's from the verado work because they increase boost from the supercharger so you will see noticeable gains...With the 2 strokes, I wasnt spending the money.
07-30-2019, 03:56 PM #66000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
DBR has stage kits. Remapped and parts.
Main issue with opti is the inability to bump compression up and have them run.
07-30-2019, 08:00 PM #7Member
- Jun 2019
- Tulsa
- 32
I went for a spin today, as is I added 200 lbs and lost 12 mph I can lose that 200 and another 200 and if I gain 8 mph over the normal 86 I'm happy. The ecu will still add 20hp, probably 3mph. I just wish I could lose the extra 125 lbs the 250 pro weighs over the old 2.5. This boat originally had the 300x but I didn't get a chance to buy it.
07-30-2019, 08:07 PM #8Member
- Jun 2019
- Tulsa
- 32
This is one device I've seen
https://www.magnumtuning.com/en/deta...optimax-pro-xs
07-30-2019, 09:10 PM #95000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
08-05-2019, 06:49 AM #10Junior Member
- Aug 2019
- Butler, PA
- 7
I agree on this as well!
08-28-2019, 08:44 PM #115000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
09-07-2019, 08:48 PM #12
The Scorpion is a great boat but to make these go fast with an outboard, you have to fix what works AGAINST having an outboard. These boats were all designed as squirt boats with a Big Block putting 750# a foot or so ahead of the transom and the center pod has quite a hook to support this design to load the pump. If you de-rig the boat so you can flip it, and measure three feet from the trailing edge of the center sponson, start with the 2" step and cut it out. Flatten the center pod and remove the hook... then re-rig and enjoy the zero trim flight that will let your boat fly as it should with an outboard.
3.0 performance mods
By fastnfish in forum Technical DiscussionReplies: 9Last Post: 07-31-2019, 01:17 PM -
v4 omc performance mods any one know of any
By xpressboat87 in forum Technical DiscussionReplies: 51Last Post: 07-09-2018, 05:12 PM -
E-tec performance mods
By mike dominick in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 3Last Post: 02-04-2011, 11:17 AM -
Mercury Tech: 2.ol performance mods?
By alxb2003 in forum Technical DiscussionReplies: 1Last Post: 07-18-2010, 03:23 AM -
260 efi performance mods
By KaamaScarab30 in forum Technical DiscussionReplies: 5Last Post: 06-01-2005, 06:55 PM
