Results 1 to 7 of 7
Thread: Loosing Water PSI
07-29-2019, 06:48 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
Loosing Water PSI
My Problem/Question is, I have a CLE lower unit that with the pass 2 weekends out and it is sucking in weeds at 2 different lakes and loosing PSI. I have a new water pump and stats,i leave the dock at 15 psi and loose it in the no wake zone. 200 EFI-i am going back to a stock lower unit,But is there a Mod to the CLE that will stop this,has anyone ever tried to Epoxy a screen to a CLE. Thank you
07-29-2019, 08:11 PM #2
stay out of the weeds lol
specboatops liked this post
07-30-2019, 05:42 AM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
I wouldn’t do that !! Your restricting the inventory and robbing water to pump ...
Jay
Jay @ JSRE
07-30-2019, 08:20 AM #45000 RPM
- Mar 2018
- NJ
- 196
- 10
Jay--Thank you for the reply. Not trying to redesign the CLE,is it possible to make the 2 intake holes bigger then add a screen. I appreciate your input. I do run T&P gauges. Thank you
07-30-2019, 12:13 PM #5
Need to weld up the 2 holes and redrill 4 or 5 a bit smaller holes. Copy the Bob’s nose cone.
Common problem here on LI with 2 hole units and weed.
Dave Strong liked this post
07-30-2019, 09:01 PM #6
I went up 3 drill sizes on my 2 hole cle,s they seem to be just fine we have weeds too
07-31-2019, 04:53 AM #7
I'be concerned getting weed sucked up into the passages especially if you have small windows.
Yamaha Tech: 300 HPDI Loosing RPM
By Tomba in forum Technical DiscussionReplies: 12Last Post: 06-14-2011, 10:08 PM -
Mercury Tech: 300 pro max loosing power
By snosuxs in forum Technical DiscussionReplies: 2Last Post: 10-02-2009, 07:32 PM -
4-strock loosing RPM's
By CNT in forum Technical DiscussionReplies: 6Last Post: 06-15-2009, 01:20 PM -
Sportmaster loosing oil
By Goofour in forum Technical DiscussionReplies: 2Last Post: 08-07-2003, 09:52 PM -
Loosing the Lavey
By BilDewey in forum General Boating DiscussionReplies: 2Last Post: 06-19-2002, 10:25 PM
