Results 1 to 10 of 10
    Dedicated clockwise Speedmaster water pump?
ID:	445630Click image for larger version.
ID:	445631Click image for larger version.
    DR/FGS bolt patterns, water inlet on body like DR housings, but a dedicated clockwise pump, cast not machined from billet. No casting numbers, no serial number, just RH
  2. Likes SixCylRunabout liked this post
    Fond du Lac WI
    Quote Originally Posted by Mark75H View Post
    Early unit? maybe not even CNC machined pump?
    u know why the double sets of mounting holes in the back?...
    Dec 2001
    Merc mystery........not seen one like that.....late one for non... dr? But it prob pumps water better.... the Dr ones had less offset on the cover because they had to work both ways.
    Also at the front. As I said in the original post, this has both the DR and FGS bolt patterns; same as the rest of its early FGS Speedmaster sisters, but unlike the FGS Speedmasters it has the water inlets on the body rather than on the nosecone.
    just another transitional piece...
  9. #8
    Deadend prototype that never evolved into a production piece. Transitions to nothing.
  10. #9
    Dec 2001
    Die cast.......
  11. Likes Mark75H liked this post
    Dec 2001
    The early ones with one stud up front were ... marked CR..... the later ones were marked RH.......And both had water pickup in the cone......Would like to see the bottom of the top w/p housing.
  1. water pump lower housing for speedmaster
    By xskid1 in forum Misc. Parts and Accessories
    Last Post: 12-29-2014, 10:10 PM
  2. Clockwise or counter clockwise ??? Extreme technical question
    By mercpunk in forum Technical Discussion
    Last Post: 08-24-2011, 04:00 PM
  3. Replies: 9
    Last Post: 03-30-2004, 02:52 PM
