Results 1 to 3 of 3
Thread: Actuator replacement help
07-23-2019, 10:10 PM #1
Hey can i just tighten up the side bolts on my Hydraulic jack plate enough to drive out the pins and not have the motor slam to the floor ?
07-25-2019, 01:27 PM #25000 RPM
- Sep 2017
- ontario
- 716
- 68
- 43
- 73
- 171
I only suspect your servicing the lift and I would at least ensure that you place blocks of wood under the skeg minimum to act as a secondary safety to ensure that doesn' happen or at least use a small engine lift with an eye as well . I hope this helps . Safety and not wrecking something is key to improvements .
07-25-2019, 07:29 PM #3
That's what I did when I had to pull the lift cylinder. I put blocks and lowered it until the skeg was on the blocks...then my grandson (2) turned the steering wheel and a blocks came out. Didn't hurt anything because it only dropped down the the next block, 1 1/2".
96 Cougar 23 MTR twin 300XS's. 100 something
98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
85 Baker RST 220 Laser SOLD
actuator
By berdes in forum General Boating DiscussionReplies: 5Last Post: 05-21-2019, 07:49 PM -
trim actuator
By tcrabtree in forum Technical DiscussionReplies: 4Last Post: 09-21-2009, 12:46 AM
