Results 1 to 3 of 3
    Prince George B.C. Canada
    Actuator replacement help
    Hey can i just tighten up the side bolts on my Hydraulic jack plate enough to drive out the pins and not have the motor slam to the floor ?
    Sep 2017
    ontario
    I only suspect your servicing the lift and I would at least ensure that you place blocks of wood under the skeg minimum to act as a secondary safety to ensure that doesn' happen or at least use a small engine lift with an eye as well . I hope this helps . Safety and not wrecking something is key to improvements .
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by kellytheaker View Post
    That's what I did when I had to pull the lift cylinder. I put blocks and lowered it until the skeg was on the blocks...then my grandson (2) turned the steering wheel and a blocks came out. Didn't hurt anything because it only dropped down the the next block, 1 1/2".
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
  1. actuator
    By berdes in forum General Boating Discussion
    Last Post: 05-21-2019, 07:49 PM
  2. trim actuator
    By tcrabtree in forum Technical Discussion
    Last Post: 09-21-2009, 12:46 AM
