Results 1 to 4 of 4
Thread: 1987 sutphen
    Jul 2018
    Connecticut
    1987 sutphen
    1987 20' Sutphen
    Boat has a 1992 Mercury Black Max 275 that was rebuilt apox. 60 hours ago. ?Included cylinder sleeves and pistons, head work, gaskets, and carburetor rebuilds. Have all paperwork on engine work to go alone with the boat. The boat has exceptional speeds and stability in the chop, the deep v cuts very well through the waves and is just an absolute blast to ride.
    Since then the boat has had the following Installed/Replaced:
    New Floors
    Transom had added support to better withstand the weight of the motor and the speed of the boat.
    Upholstery
    Infinity Marine Flooring
    Gas tank (40 Gallons)
    Replaced both switch boxes on motor
    Water pump replaced
    Lower Unit lube changed 10 hours ago
    Interior LED Lighting
    Complete JBL Audio system with Wet Sounds light and music remote controller
    All the gauges work on the boat except the Trim indicator. The boat can run a solid 55mph cruise and has topped out around 72mph
    Also have a multitude of props to go with the boat depending on what your interests are... Fuel savings, Water Skiing, or just going fast.
    Please if you have any other questions don't hesitate to ask!
    8602354477
ID:	445216Click image for larger version.
ID:	445217Click image for larger version.
ID:	445218Click image for larger version.
ID:	445215Click image for larger version.
    Jun 2002
    Waterford, CT
    Price?
    Mar 2016
    Anza, CA
    Yes what's the asking price and length of boat.
    Mar 2016
    Anza, CA
    What sort of speed also?
  1. sutphen
    By genob in forum Ebay Listings and Other Internet Listings
    Last Post: 01-17-2018, 09:12 PM
  2. New Sutphen 210?
    By Donzied in forum General Boating Discussion
    Last Post: 09-29-2005, 04:51 PM
  3. Sutphen Gen III
    By hevysrf in forum General Boating Discussion
    Last Post: 12-16-2003, 10:13 PM
Spinelli Props
