Results 1 to 13 of 13
Thread: TPS adjustment?
07-22-2019, 07:19 AM #1Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
TPS adjustment?
I have seen it on here before, but couldn't find it again. Can someone post up the TPS check and adjustment procedure on a 96 200 EFI?
07-22-2019, 11:55 AM #2Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
With my limited search skills I was able to find this:
https://www.screamandfly.com/showthr...200+tps+adjust
Not sure if that is of any use to you, but it is the best I could come up with.
A while back somebody posted how to use the search function properly. I wish I would have bookmarked it.
07-22-2019, 01:00 PM #3
Use the Merc tool 91-816085, disconnect the 2 tan/blk temp sensor wires on port side temp sensor. Turn key on rotate sensor fully clockwise with throttle closed, adjust to .240- .260v. Slowly open throttle to wide open voltage should change smoothly and be around 7.46v at wide open. Never seem to get the exact wide open value the say but over 7v should be good.
tux974, texasvector liked this post
07-22-2019, 01:42 PM #4Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Thanks for the info Dave and minnow. The thread I was looking for was for the shade tree mechanic version where you use small stiff wires stuck into the plug. But with the correct number values I should be able to figure it out. I kept getting results where it may have been buried in the middle of 20 posts, but made no reference to it in the title.
07-22-2019, 01:48 PM #5The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
LakeFever liked this post
07-22-2019, 02:42 PM #6Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Working on it boss. Be on your desk in the am....
07-22-2019, 04:17 PM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
Dave is right on +++ 1
JaybJay @ JSRE
Dave Strong liked this post
07-27-2019, 03:23 PM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Got er dun... Used small stiff wires to get into the connectors at the wire entrance. Hooked up meter with alligator clips to blue and tan wires Pulled the temp wires and got .220. Reset to .250 Got .726 at wot. Was wondering, Is a lower number setting going leaner? Or richer? Man those things are touchy. Just turning the screws would change it.
07-27-2019, 03:27 PM #9
07-27-2019, 03:49 PM #10Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I never have adj. tps on this one. But it got decent fuel economy. 3-4 mpg on my stream. When I saw it was on the low side it made me wonder. What's the lowest number you can go if you know.
07-27-2019, 04:30 PM #11
They say to adjust between .240 and .260
07-27-2019, 08:36 PM #126000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Hope that’s 7.26 not .726 at wot.
Closer to .260 will keep you running if theirs a blip in voltage or a stiff shift or burry the relief backing up. Some say easier starts when cool never really say that though.
07-28-2019, 03:23 AM #13Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Yes, 7.26 Thank's for the info guys. Heading out in an hr to go fishing. Will see how it runs. Should run better since it was off by .20 at least. It did stall some when idling on the stream , and was not happy when it was cold at startup. Ran good on the hose yesterday. No stalling...Fired right up. Re-timed to 23 deg. from 25 and put stock heads back on. It's a fishing motor now, pushing my flats boat.
TPS adjustment 95 XRI
By THEFERMANATOR in forum Technical DiscussionReplies: 7Last Post: 05-03-2008, 07:49 PM -
tie bar adjustment
By markt111 in forum Props, Setup, and RiggingReplies: 0Last Post: 05-29-2007, 11:08 AM -
Float adjustment on OMC
By markt111 in forum Technical DiscussionReplies: 5Last Post: 06-16-2005, 09:41 AM -
TPS Adjustment
By Tiller in forum Technical DiscussionReplies: 23Last Post: 07-29-2003, 05:12 PM -
TPS adjustment
By Terry Jackson in forum Technical DiscussionReplies: 2Last Post: 03-28-2003, 09:51 AM
