Results 16 to 30 of 32
    Excellent job. I see that you repaired the trans from the outside. Some will say that is a no-no. If done properly, I disagree.
  2. Likes keegs liked this post
  3. #17
    Apr 2019
    Queensland, Australia
    Agree. This was considered at length and I did debate it amongst myself and others. In the end it seemed to make more sense to do it from the outside given the respective state of the transom on the outer / inner skin, as well as the cap and the other work we were going to do. In the end we replaced the outer skin with what I would say is a better job than was originally done, especially considering what had happened to it over the years through poor rigging etc.
  4. #18
    Apr 2019
    New trailer + boat goes in for it's exterior paint / wrap.
    Have made some exciting rigging / equipment choices including a custom MoTeC C1212 dash - so will keep you all posted when that's starts too.
ID:	446236Click image for larger version.
ID:	446237Click image for larger version.
  5. Likes 89LASER, tnelsmn liked this post
  6. #19
    Lindenhurst, NY
    Nice work, I do like an all white boat. Good luck with it.
  7. Thanks vtboy thanked for this post
  8. #20
    Apr 2019
    New exterior wrap goes on..
ID:	448506Click image for larger version.
ID:	448507Click image for larger version.
ID:	448508Click image for larger version.
ID:	448509Click image for larger version.
  9. #21
    Apr 2019
    Electronics and wiring, what a nightmare this all was!
ID:	448896Click image for larger version.
ID:	448897Click image for larger version.
ID:	448898Click image for larger version.
ID:	448899Click image for larger version.
  10. #22
    Apr 2019
ID:	448894Click image for larger version.
  11. #23
    Jul 2005
    AZ
    Quote Originally Posted by keegs View Post
    Attachment 448511Attachment 448512Attachment 448513Attachment 448514
    All say invalid attachment...
    '84 Checkmate Convincor
  12. #24
    Apr 2019
    Should hopefully work now
  13. #25
    Jul 2005
    AZ
    Yes all show up now..
    Looks good!
  14. #26
    Small projects turn into major undertakings with a lot of money involved and once you commit there is no turning back. Glad to see you are chasing it to completion and will get to enjoy the finished product.
    Apr 2019
ID:	449553Click image for larger version.
ID:	449554Click image for larger version.
ID:	449556Click image for larger version.
ID:	449557Click image for larger version.
ID:	449558Click image for larger version.
    Attached Thumbnails Attached Thumbnails B437E8D2-B6A5-4EF4-98EB-3237334D7A40.jpg
  16. Likes noli, tnelsmn liked this post
  17. #28
    8 Post(s)
    its getting that cloth strength around the corners that makes me think its not a great way to do it?
  18. #29
    Apr 2019
    The corners aren't cut out when you repair from the rear (or they shouldn't be). A 3" or so perimeter is left in tact and the new core is then wedged into place behind that before you fibreglass the old (or new) skin into place. This is the same process set out by West System and can be found explained in a fair bit of detail here - https://www.westsystem.com/wp-conten...anual-2015.pdf
Name:	Screen Shot 2019-09-26 at 12.14.05 pm.png
  19. #30
    I have done many from the outside with zero failures. Have even re-used the outer skin on some that were in good shape. Lot of myths about glassing transoms out there that are flat out bs. If you know how to lay glass and engineer a laminated structure no problems. If you try and just putty it in, it will fail.
  1. New victory vtx 27 catamaran
    By AZMIDLYF in forum General Boating Discussion
    Last Post: 02-27-2019, 11:05 PM
  2. Another Bush Victory
    By Liqui-Fly in forum The Scream And Fly Lounge
    Last Post: 06-27-2008, 11:31 AM
  3. Victory by Design
    By Capt.Insane-o in forum The Scream And Fly Lounge
    Last Post: 12-31-2003, 01:59 PM
  4. Victory lap!! Recognition!!!
    By gdfatha in forum General Boating Discussion
    Last Post: 06-18-2003, 03:25 PM
  5. One Small victory...
    By Reese in forum The Scream And Fly Lounge
    Last Post: 02-20-2003, 01:47 PM
