Results 1 to 15 of 15
07-21-2019, 08:17 PM #1
Installing a Heli-Coil on a 2.5 Hi-perf Block...Best way to Drill Out Old Hole...Help
I need to install a Heli-Coil in a 2.5 Block.
I have done this with a hand held drill several times before, and had success, with no guide.
I have since become more cautious, and would like any advice on how to drill it with a portable guide of some sort (what type of guide?).
I don't want to strip the bock down and take to a machinist, if I don't have to.
Any good advice is appreciated.
Thanks
Greg"The Flying Clamato"
...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
The G-Train has left the station.
07-21-2019, 10:12 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
If I have time I step up the tap set and screw it in.
Ive also gone with a step bit to make a guide hole.
Theirs a special bit available that has a sheath that keeps the bit square.
As as long as you have lube and a good tip on the bit it should go straight
07-22-2019, 05:43 AM #3
If you want a guide for drilling it square, drill a clearance hole in a 3/4" piece of aluminum. Line it up over the hole to drill. Hold it with one hand, drill with the other. Depending on where you are drilling, you could also make the guide block large enough to pick up another threaded hole and use it to hold it down.
07-22-2019, 06:49 AM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
JMO Might look at the Time Sert thread repair method I’ve been very successful with them for years they are an insert and no need to “stack” to get full length of thread repair needed , if your repairing head bolt thread damage they make an insert that’s 1”.200” long perfect for head bolt thread repair , the kits aren’t cheap but neither are blocks ....
Good luck if you need part numbers for your repair call me ,
Jay @ JSREJay @ JSRE
Whaaaaat liked this post
07-22-2019, 08:40 AM #5
Thinking about it, why couldn't I use an old head as a Guide?
This is a head bolt on a 2.5 Drag. I have some old 260 heads that the pattern is the same.
Jay, what is the part # for the Time Sert?
Thanks you guys for giving me ideas
07-22-2019, 09:28 AM #6
If you don't have access to a mill and a 30* fixture to level the deck. Then the above is your best bet for getting the pilot hole straight.
If you go the Time-cert method, you might want to stick with the stainless inserts which only go up to 1.000" ( more than enough thread @ three times bolt diam. )
Or if you do put a mild steel 1.200" insert in the hole, make sure it's waxed shut if you ever send the block in to be replated.
Heli-coil makes a straight one-piece insert's in both 1.000" and 1.250" long .375 x 16 in stainless that wouldn't be affected by the acid bath @ the platers. Just thinking ahead ...
07-22-2019, 11:11 AM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
Greg , pictures and information ( parts numbers and phone number ) sent !
Good luck ,
07-22-2019, 11:12 AM #8
Thanks Jay...Good Stuff
07-22-2019, 11:50 AM #9
If the bolt is steel and the block aluminum I weld nuts on top of flush broke bolts all the time with 100% success so far ( auto heads ) but if its broke down the hole a bit and theres some threads avail? I center drill out a threaded bolt 1/8" or so on the drill press and thread that into the hole to use as a pilot guide then hand drill and its perfectly centered so you dont drill askew. Once you have your center you can carefully hand drill the rest or use an extractor
07-22-2019, 01:16 PM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
while on the subject, does anyone stud they're blocks, for the heads, like we used to do with Champ race blocks, a million years ago? or is that a no-no these days?
07-22-2019, 01:32 PM #11
Fujimo...This is a Stud that pulled out. I tightened to the wrong spec and pulled the threads in this one hole. I try to always use Studs, I know others like the bolts.
07-22-2019, 01:41 PM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
gotcha
07-22-2019, 03:39 PM #13Supporting Vendor
- 11,838
- 163
- 11
- 795
JMO , I’ve NEVER use studs in heads ever ... Just built a drag motor that was studded put the set in the trash can , motor had 3/8” coarse all thread ( junk ) , bought and installed new set of the proper bolts from WSM done deal ...
Disclaimer :
BTW All I respond to on any post is simply my opinion and what’s successfully worked for me and my customers for the 25 years I’ve been building and racing these engines , some may agree some disagree you’ll not hurt my feelings at all ..
God bless,
Jay @ JSRELast edited by Jay Smith; 07-22-2019 at 04:03 PM.
Jay @ JSRE
07-22-2019, 08:11 PM #14"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
07-23-2019, 09:40 AM #15
I thought there was a bolt stuck in it I was in a rush and didnt read. Use varsol for cutting fluid on aluminum and it comes out very nice with no burrs or galls. A guide tube of some sort is ideal and whenever I need a tool that I dont have I tend to make a tool that does the job. A small piece of plate with two head bolt holes drilled you can bolt down flush 1/4" thick or whatever you have, you could even use plywood if you like. Then a drilled guide billet or pipe plotted out directly over the hole and welded or fastened to the base plate will keep the bit true. Hope some of this helps
Where do I drill second hole on torque master for water inlet
By Donat in forum General Boating DiscussionReplies: 8Last Post: 08-14-2015, 01:15 PM -
OMC Tech: Two hole looper coil should show continueity between black wire and metal bracket?
By audiobill5 in forum Technical DiscussionReplies: 2Last Post: 09-10-2010, 02:22 PM -
Heli Coil - Backyard Style
By sschefer in forum The Scream And Fly LoungeReplies: 6Last Post: 07-16-2010, 06:58 PM -
Scientists Will Drill Hole
By j_martin in forum The Scream And Fly LoungeReplies: 0Last Post: 11-21-2009, 12:11 PM -
Drill,Tap Hole?
By tj309 in forum Technical DiscussionReplies: 6Last Post: 04-14-2006, 07:11 AM
