Results 1 to 2 of 2
    10 minutes from the lower Fox
    115 Merc 4-stroke trim oscillates while trying to trim up
    Posting for a friend who has come up empty on troubleshooting this thing. 2017 Merc 115 4-stroke. When trimming the motor up while underway, the motor comes up partway and then won't go further, but oscillates a little bit up and down in one position. Dealer replaced the entire pump, so it wouldn't seem to be in there. Left it partly trimmed overnight and nothing bled down either. It appears to have three trim relays; none have been replaced yet. We were out on the boat yesterday and the trim gauge also went wacky. Anyone have any insight? I'm wondering if the gauge problem is related...maybe a bad trim sensor causing it to think that it is at max trim? Not sure how the system works or if any of it could be Smartcraft related. Thanks.
    Ron V
    Feb 2014
    Missouri
    Some have a physical limiter basically a port in the piston tube if you’re there on a transom that’s has a high angle. Trim extensions is about the only fix or wedges.
    If not it it could be shock valve or other manifold things
    Make sure the manual trim thing is all the way in.
  1. InLine Merc Racing Quik trim power trim rams
    By Tom Smyth in forum Parts Wanted
    Last Post: 12-05-2015, 02:22 PM
  2. removing trim ram in a 84 200 merc, single ram trim.....
    By syclone01 in forum Technical Discussion
    Last Post: 02-27-2011, 11:36 PM
