Results 1 to 2 of 2
07-18-2019, 06:01 PM #1
Part Number of a Sportmaster Gearcase
I have done several searches on here with no luck, so I will appeal to the more knowing. Where is the part number for the gear case generally located for a 2.5 gearcase. It is not on the top stamped by the gear ratio, I found one tiny number between the back mounting holes but it doesn't match anything. Where is it usually found?
07-22-2019, 05:16 AM #2
Ive never seen a PT# stamped on a Gear case only the ratio. But if its the Part# you are needing its
1687-8M0083306 GEAR HOUSING ASSEMBLY, Basic 848450A25 SS/ACT $2,888.57 $2,586.39 1 1687-8M0084203 GEAR HOUSING ASSEMBLY, Basic-Without Torque Tab 848474A39 SS/ACT $2,888.57 $2,586.39 1 Bud Conner "Heathen" "Defending Our Constitution"
relay number for 225 pro max trim and tilt part number?????
By bill mason in forum Technical DiscussionReplies: 2Last Post: 02-07-2019, 06:43 AM -
Mercury Tech: sportmaster carrier part number
By speedinstream in forum Technical DiscussionReplies: 7Last Post: 04-16-2014, 05:38 PM -
Part Number for Flo-Tor Hub on 2.5l Fat Shaft sportmaster?
By tony97gt in forum General Boating DiscussionReplies: 9Last Post: 06-01-2013, 10:00 AM -
Mercury Sportmaster Bearing Part Number?
By steve in forum Technical DiscussionReplies: 1Last Post: 01-15-2004, 06:14 PM -
Need Part number Gearcase bearing
By steve in forum Technical DiscussionReplies: 0Last Post: 01-11-2004, 09:40 PM
