Results 1 to 2 of 2
    Jun 2004
    Alva Fl
    Part Number of a Sportmaster Gearcase
    I have done several searches on here with no luck, so I will appeal to the more knowing. Where is the part number for the gear case generally located for a 2.5 gearcase. It is not on the top stamped by the gear ratio, I found one tiny number between the back mounting holes but it doesn't match anything. Where is it usually found?
    Ive never seen a PT# stamped on a Gear case only the ratio. But if its the Part# you are needing its
    1687-8M0083306 GEAR HOUSING ASSEMBLY, Basic 848450A25 SS/ACT $2,888.57 $2,586.39 1
    1687-8M0084203 GEAR HOUSING ASSEMBLY, Basic-Without Torque Tab 848474A39 SS/ACT $2,888.57 $2,586.39 1
    Quote Originally Posted by Beak Boater View Post
  1. relay number for 225 pro max trim and tilt part number?????
    By bill mason in forum Technical Discussion
    Last Post: 02-07-2019, 06:43 AM
  2. Mercury Tech: sportmaster carrier part number
    By speedinstream in forum Technical Discussion
    Last Post: 04-16-2014, 05:38 PM
  3. Part Number for Flo-Tor Hub on 2.5l Fat Shaft sportmaster?
    By tony97gt in forum General Boating Discussion
    Last Post: 06-01-2013, 10:00 AM
  4. Mercury Sportmaster Bearing Part Number?
    By steve in forum Technical Discussion
    Last Post: 01-15-2004, 06:14 PM
  5. Need Part number Gearcase bearing
    Last Post: 01-11-2004, 09:40 PM
