Results 1 to 3 of 3
    Jul 2019
    Chateaugay NY
    1977 Johnson 175TL77S pisser
    Hey guys I have this 88 Hydrostream Valero with a Johnson 175TL77S and this motor doesn’t have a water pisser or a pressure gauge. Where would I tap into it to get a pisser and pressure? All my other outboards had a hose on the heads but this has those 2 piece water jacketed heads on it and no hoses off the thermostats. This thing is way before my time on God’s green earth so any help is appreciated. Thanks
    Attached Thumbnails Attached Thumbnails AEF1BFB5-67AB-4503-90D6-ACF573309B07.jpg
    Jan 2008
    SUMMERVILLE S.C.
    i usually tap right thru the top of the block into the water jacket..gives you a pressure port and keeps any air bubbles out of the block
    MIAMI FLORIDA
    Later models were taped 1/8 pipe in the raised area at the bottom of the exhaust cover on the back of the block,,
  1. Buy My Johnson: 1977 115 V4 with Power Trim
    By 427Man in forum Outboard Engines
    Last Post: 09-25-2016, 08:37 AM
  2. 1977 Johnson 115 overheating after new water pump
    By Newboatowner in forum Technical Discussion
    Last Post: 07-22-2008, 04:47 PM
  3. OMC Tech: 1977 Johnson 70 hp timing specs
    By gatahiti in forum Technical Discussion
    Last Post: 07-06-2008, 03:09 PM
