Results 1 to 10 of 10
    Dec 2006
    Mt. Laurel, N.J.
    13 spline 15,16 or 17 pitch
    I'm looking for a 4 blade, 15 16 or 17 pitch 13 spline for OMC v4.
    Thanks
    Azure AZ259, 8.1
    Lake Coochiching, Ontario
    I have a 17" 4 blade Stiletto from my V4 days. It would pull a 200 lb slalom skier out slowly with a 100 crossflow and quickly with a 115 HO
    It ran 53ish with the Crossflow on a 16 Baja (correction: this is an error and obviously inconsistent with the speed with the 115 HO)
    It ran 50+/- on the Baja with the 115 HO, depended what the rev limiter would give
    47+ with the 115 HO on a 19 J Craft
    Perfect condition. I'll get pictures this weekend
    Dec 2006
    Mt. Laurel, N.J.
    I'm interested.
    Azure AZ259, 8.1
    pictures (I can e mail more)Click image for larger version.
ID:	444968Click image for larger version.
ID:	444969Click image for larger version.
    Dec 2006
    Mt. Laurel, N.J.
    How much?
    Azure AZ259, 8.1
    $300 plus shipping
    $250
    Dec 2006
    Mt. Laurel, N.J.
    To run 53 mph it would have to have more pitch then 17.
    Azure AZ259, 8.1
    Dec 2006
    Mt. Laurel, N.J.
    Unless you spun that motor 7000 rpm
    Azure AZ259, 8.1
    You are correct about the 53. I noted the correction above.
    Even 50 calculates as negative slip. The prop did run tall for its rated pitch. But it pulled great for skiing so it was good for what we wanted.
  1. I need a 13 spline 23 pitch
    By Towman5000 in forum Propellers Wanted
    Last Post: 04-26-2019, 06:59 PM
  2. WTB 18 to 20 pitch 13 spline
    By gotboostedvr6 in forum Propellers Wanted
    Last Post: 09-27-2016, 12:49 PM
  3. OMC 19 - 21 pitch 13 spline for v4
    By Kristiismean in forum Propellers Wanted
    Last Post: 06-21-2016, 08:38 AM
  4. WTB: a few low pitch 13 spline props 9, 10,11,12,13p
    Last Post: 09-04-2015, 08:47 PM
